Here's a bit of myth-busting wisdom I'd like to share, to get this information I destroyed 2 brand new batteries - in the name of science
About battery drain... I did an experiment with car battery capacity some years ago. If you start out with a brand new battery with say, "60 amp/hr" printed on it, after only a few partial discharge/charge cycles that 60 A/hr charge capacity rapidly reduces at first, levels out and eventually stabilises at a rather low value very much less than 60.
All the time this is happening, the voltage remains the same and you would never notice this, but get this... a car battery can STILL start the car when there is just 1A/hr remaining of the orginal 60 A/hr of capacity left! A car start will require at the very most 3 seconds of 500 Amps, which works out as a fraction of an Amp-hour of energy. Because of the internal geometry of a car battery it still delivers a big current while the last dregs of energy remain.
When there is no standby current drain in a car, the battery has an easy life and with the majority of cars becoming like this, the battery naturally evolves into the cheapest way of providing the bolt of energy, at the expense of other qualities such as tolerance to deeper discharge cycles (which would never be used).
Now for some more sums, if the standby drain is 0.05A, that works out as 1.2A/hrs drain per day. Over a week that's a now a total of 8.4 A/hrs of discharge. This is not good for a car battery with low tolerance to deep discharge, as it's design has probably been optimised to be cheap to make instead.
This is why disconnecting the battery makes the difference between starting or not starting after a period of non-use. If your battery has degraded to 6A/hr and you didn't disconnect it, then after a week it would be too flat to start the car.
This is also why the battery conditioner works so well, and why it's also (in part) a myth that the charger main function is to 'keep the battery topped up with charge'. This is because at the point of connecting the charger, the battery is already fully charged from the journey home (if the charging system is working correctly) and a battery's self discharge is very low in comparison with the standby current drain. The charger is actually supplying that 0.05 Amp standby drain (the charger believes the battery is taking the current, but it doesn't matter). Since the charger is providing the standby current instead of the battery, the battery lasts a lot longer.
So the conclusion is, the best thing you can do is attach a charger on the same day you leave the car for an extended period. The charger doesn't need to go directly across the battery if it's only ever supplying the standby current, it could connect to say the cigarette lighter for example. The charger must be the kind that can be left on permanantly without damaging the battery. If you don't have a charger and know the car will be idle on a regular basis for weeks at a time, it will be a good thing to disconnect the battery. However, remember it might be better for you to 'spend' a battery if you require the car alarm to be active or don't have the radio code to re-enter.
