Replacement ECU problems
Posted: Sun Oct 30, 2005 6:45 pm
by Sheepy
Evening All,
Getting close to my kitty being ready for the dreaded MOT inspector (She's been off the road since Feb). One item which is bugging me it the ECU.
On her old ECU, the idle was erratic, which I believe is down to the vaccuum measurement being off. So as a trial, I picked up another 8CU ECU off ebay for £10. When I first used it, the fuel pump didn't run, but the car did try to start. Switching back to the old ECU got her started, and once warmed up, I tried the new ECU again. Hey presto it worked fine, and the erratic idle had disappeared.
That was a couple of weeks ago. Now, however I find I can't get it to work again. The new ECU just seems to refuse to prime the fuel pump.
I'm wondering whether I could bypass the ECU for the pump, by triggering its relay from the ignition directly. This would mean having the pump running any time the ignition is live, but I could fit a switch (as an extra security measure!!).
Does anyone have any suggestions, or see a drawback to this plan?
Sheepy
Posted: Mon Oct 31, 2005 1:29 am
by Mark_B
I'm not completely sure whether the pump is meant to prime a short time when the ignition is first turned on before cranking. I do know for sure it's meant to run when the engine is cranking and when running. It's meant to stop as soon as the engine stalls with ignition on. The idea of that is to prevent the chambers filling up with fuel should an injector be leaking.
Posted: Mon Oct 31, 2005 9:50 am
by Sheepy
Hi Mark,
My old ECU primes the pump when the ignition is turned to the normal running position. The new ECU doesn't do this, infact the pump never runs even when you try to fire the engine.
It did work for an afternoon, but has stopped. I'm tempted to take the new ECU apart to check for dry-joints / damaged components. I'm also trying to trace the fuel control cct to see if I could mix and match between the two ECUs to get one working one.
As an alternative, I thought about just running a feed directly to the fuel pump relay and controlling the pump that way, but I'd have to take the safety switch into account.
Sheepy
Posted: Mon Oct 31, 2005 2:04 pm
by Mark_B
There's a very good guide to fuel system electronics in the factory service manual (not the crappy haynes manual!) which tells you about each component function and its electrical signals in detail. Beware the lucas pcb is multilayer and the middle tracks can break if solder joints are re-worked without good reason.
<on techy level 5 (on scale of 5)>
I guess if all fails and you're still thinking about hardwiring with a switch, a better solution you add a veroboard circuit with monostable pulse stretcher and relay to drive the fuel pump feed instead. A power on timer on the mono. does the prime. Supplied and triggered off the fuel injector pulses from round the back of the trip computer and a wire off to the pump feed disconnected from the ECU. Should prevent a bent conrod/dented bigend shell.
