Auxiliary cooling fan
steve_m
Postby steve_m » Fri Jun 29, 2012 9:13 pm
The auxiliary fan on my 86 V12 XJSC does not run and I've been right back to the start of the BB without finding an answer.
I've cleaned all the obvious contacts and the fan does operate when connected directly to a battery so there is probably a faulty relay or thermostatic switch somewhere that I need to look at; where would they be located.
Steve
Re: Auxiliary cooling fan
Postby Brakebuster » Fri Jun 29, 2012 9:41 pm
the auxiliary fan was used for extra cooling when the AC was being used, it compensated for the extra load
this did change towards the 1989 cars where it was simply an extra electric fan to assist the viscous fitting , and had no connection with the AC
so , i would start with getting a schematic circuit drawing for your particular model , and do a bit of detective work ,
steve_m
Postby steve_m » Fri Jun 29, 2012 10:01 pm
Does that mean that the fan will not run unless the aircon is operating? At the moment there is no gas in the system so the compressor should not cut in; would the fan be controlled from a pressure switch or from the aircon control switch?
Would there be a suitable live feed anywhere in the tangle of wiring under the bonnet where I could take a direct feed from?
Steve
poprivet
Postby poprivet » Sat Jun 30, 2012 1:58 pm
Hi Steve, are you saying that the engine overheats? if not, maybe the fan isn't being called for.
As BB rightly says, there are many variations to the wiring, not all documented let alone what previous owners may have altered. There will be a 2 wire thermostat on the radiator which can be shorted at its connection plug to hear the relay click, it could also be the diode pack at fault. The good thing is that you know the fan itself is good. Even without the A/C, the aux fan should run if the radiator gets too hot.
Have a look at http://www.captainjaguarscathouse.com/E ... erence.htm which seems to cover most wiring scenarios encountered, although you may have to dig around a bit to find the appropriate diagram.
Keep us informed how you get on.
steve_m
Postby steve_m » Sat Jun 30, 2012 6:14 pm
Thanks Pop Rivet.
That is a excellent link to a an excellent website; does everybody know about it? My other question about relays has been answered immediately.
Yes the car does overheat which is why I want to get the auxy fan working even if I have to fit a manual switch to it, I just need to find a live feed somewhere.
Part of the overheating is water bubbling out of the filler cap which obviously isn't sealing properly; once the new caps arrive I'll smooth of the filler top so that it should seal properly.
The car only overheats in traffic (which is pretty much all the time these days) but is fine on the open road. The fuse to the fan appears to be ok and the wiring all appears to be original (probably part of the problem) as it all seems to snake out of the looms. The only addition appears to be an alarm which goes off occaisionally at random but I don't have any means of switching it on or off as the car didn't have a fob with it.
As you can see I have lots of things to keep me occupied (for several years by the look of it) but I just want to get the car driveable for what now passes as a summer and then attack it in the winter.
I've also got an old wooden river boat that has very interesting wiring to sort out because it has a home installed 240V system along with the 12V one.
Steve
dhdove
Postby dhdove » Sat Jun 30, 2012 7:26 pm
"The car only overheats in traffic (which is pretty much all the time these days) but is fine on the open road"
Steve
This seems like a pretty classic XJS fault......have you replaced the rad or has it been replaced recently in the cars history?
IF NOT
I think you may find that the rad matrix is chock a block with crap, leaves, twigs etc. and has a generous coating of old engine oil, power steering fluid etc. In addition the inside of the rad is probably at least half full of sludge.....(in which case it will be twice as heavy as it's replacement). Add to that it is probable that the inter tube matrix is probably mostly missing.......
It is almost impossible to see this problem until the rad comes out.
Solution:- new/more likely re-con rad and you will not believe the difference :? If you want to go ultra cool ask for a tropical core - more tubes.
Budget for around £300.00 ?
It really does transform the car :D
IF IT HAS A NEW RAD........
.......please ignore this post :mrgreen:
TonyS
XJS Bulletin Board Moderator
steve_m
Postby steve_m » Sat Jun 30, 2012 9:00 pm
Thanks Tony.
It's been a while since this particular monster has had anything new put into it before I stumbled across it but I've never been one to let something so dull as experience get in the way of anything that I fancied.
The fact that the car will run fractionally below normal at posted speed limits leads me to believe(optimistically obviously) that it is not a totally dire situation; the MGC that I had decades ago used to run slightly warm until I fitted a Kenlowe fan then it was fine.
Once I get the steering rack leaks and fuel tank vents and electrics sorted out I'm sure it will be a great car. And the cruise control. And the passenger window. And the new stereo that is faulty. And the seized caliper nipple. And the brake fluid float switch. And the blown sealed beam headlight. And the boot catch.
I need a drink.
Steve
steve_m
Postby steve_m » Mon Jul 16, 2012 7:00 pm
I've located the diode module connector block and there was nothing in it which explains a lot. Fitted a new module, took the car for a run and hey presto, the fan works and continues to run for about a minute after switching off.
Car still running hot though. I've replaced both radiator caps with new ones and now there is no leaking from the filler pipe neck like before and I can't see any fluid leaking anywhere else..
Rad flush next job before considering replacement. Along with the rack.
I'm hoping to get it driveable for the Prescott revival next month but it's looking unlikely at the moment.
Steve
1995 XJR6 Flamenco red
2004 X Type 2.5 Estate
kelsham
Postby kelsham » Tue Jul 17, 2012 10:18 am
If the engine overheats only when idling the likelyhood is you need a new viscous assy. once this fails or loses efficiency cooling suffers when ticking over. Also check the fan for cracks, the original yellow ones have been known to disintegrate and modify the shape of the bonnet. The replacement is black.
Regards Kels.
Postby ptjs1 » Tue Jul 17, 2012 12:07 pm
steve m,
My guess (and it is just that!) would be a sludged rad or more likely, deterioration of the colling fins in the lower third of the rad. They are really exposed to road dirt and eventually corrode and disappear. Our article in the April 2010 magazine showed this.
The fact that it overheats when stationary might indicate that the problem is the inability of the rad to become cooled without airflow, therefore possibly fan problem, blocked rad or reduced cooling surface through the fins.
As I'm sure you know, the golden rule on a Jaguar V12 is never, ever let it overheat! It will be the most expensive mistake that you'll make, as the heads will always warp! So get it fixed quick and don't take any chances!
PaulGover
Postby PaulGover » Wed Jul 18, 2012 1:06 pm
If you think it might be sludge, I found the old Holts Radflush (3 sachets of powder) very effective on the old iron XK block; I see the equivalent product from Holts is now two liquids (available from Halfords) and may be better suited to aluminium blocks.
Note that it's impossible to drain the V12 cooling system completely. You leave about 30% of the old liquid behind, so if you are using chemicals or changing antifreeze, you need to flush the system FOUR (4) times to reduce the concentration of the old water to about 1%.
Just draining is a bit tedious, as there's no drain plug. I found one of those drill-powered mini pumps connected to a meter of plastic tube ideal for inserting through the right hand vent pipe banjo. If you try this, take care to collect and count the various spacers and copper washers.
