Relays
steve_m
Relays
Postby steve_m » Fri Jun 29, 2012 9:08 pm
Whilst trying to find out why the auxiliary cooling fan is not working on my '86 V12 XJSC I decided to pull a few relays and clean the contacts.
There are 2 relays mounted centrally behind the top of the radiator and as you can see from the picture one of them fell apart! The good one is a standard Lucas unit and the broken one is a Pertron unit (which I have never heard of).
What do the 2 relays do and what type of relay (and where would I get one from) do I need to replace the broken one?
Steve
poprivet
Re: Relays
Postby poprivet » Sat Jun 30, 2012 2:18 pm
The Pektron diode module for the aux fan part number is DAC1996
steve_m
Re: Relays
Postby steve_m » Sat Jun 30, 2012 6:17 pm
Thanks to the link that you sent the relay has been identified as the wash/wipe diode module; is that the same part number as the one that you sent?
Steve
sparow
Re: Relays
Postby sparow » Mon Jul 16, 2012 10:12 pm
This may seem strange but, I have a problem with my horn constantly sounding,whenI pulled the relay it stopped the fan from working, its next to the fuses under the steering column. somehow it's part of the fan circuit. hope this may lead you somewhere.
steve_m
Re: Relays
Postby steve_m » Mon Jul 16, 2012 10:32 pm
Thanks Sparow
I have located a new diode module and the fan is working properly now although the engine still runs hot; curses!
Steve
1995 XJR6 Flamenco red
2004 X Type 2.5 Estate
kelsham
Re: Relays
Postby kelsham » Tue Jul 17, 2012 10:12 am
Have you cleaned the radiator matrix? Paying particular attention to the gap between the aircon rad and the main rad.
You will need to remove the top plate that holds the main rad in position, ease it forward and look down. It is likely the gap will be full of debris.
I used a hose to flush the matrix on mine.
I also found that the fuse link on my fan had a high resistance, cleaning the connectors visibly speeded up my fan.
The thermostats can also age and might be worth checking. They need to move the full range they are designed for to ensure they close the bypass when warm.
There is also a pipe that runs across the top of the rad with banjo ends this needs to be clear of corrosion.
Does the catch tank under the nearside front wing have a blockage in its pipework? remove the pipe from the small tank under the wing and try blowing back into the catch tank.
Regards Kels
