Electric fan
Posted: Wed Jun 02, 2010 8:50 pm
Hi Folks
The electric fan on my 1989 v12 coupe has started to come on more frequently. I thought maybe some kind of cooling issue...however tonight after charging the battery, I switched on the ignition and the fan came on (stone cold engine). When I switched the ignition off the fan continued to to run. In the end I had to disconnect the battery.
What can be causing this..switch or sensor of some kind?
Many thanks
sbb
Many thanks
sbb
