does anyone know where to get a fuse diagram for my 1989 convertable
i have a problem with the wipers not working , except when i pull the wiper lever towards me and get a single wipe , if i push the arm up there is no response
thanks
kevin
windscreen wipers
K SIMMONDS
windscreen wipers
Kevin,
It's in the "Technial Guides" section of the Parts & Service Manual. If you can't see it, let me know and I'll describe how to locate it.
Just a thought, but from memory, I think there will be a single fuse controlling power to the wiper circuit. Therefore, if you can get a single wipe, it won't be the fuse. I would probably start by looking at the arm switch itself.
rainbowhardy
windscreen wipers
I have just had to change my wiper motor two days ago, got caught in
a heavy shower of rain at the time. The fuse kept blowing on further
investigation it turned out to be the motor. As suggested above I would go with arm switch.
Phil
Phil
