Hazard flashers on a 1986 XJ-SC 3.6
Posted: Sun Oct 18, 2009 8:34 pm
by DavidCabriolet
Externally the indicator/hazard lights work when the switch is activated but the green indicator lights on the dash do not light up, except when used in the turn mode. this has resulted in a failure at the MOT test. any ideas on where the fault might be?
Posted: Sun Oct 18, 2009 9:33 pm
by Brakebuster
i would imagine it would be in the hazard lights relay, as this will be separate to the turn indicator relay,
try replacing the relay for a know good one, this should either not change anything, or make it work
hope this helps
Posted: Mon Oct 19, 2009 9:30 pm
by JED1961
they dont flash on mine !!! just the hazard warning symbol in the warning light row does ......thats all thats required for a MOT pass
