Dismantling door mirrors
Posted: Wed Sep 23, 2009 4:50 pm
by SimonR
Hi all,
Has anyone ever tried to dismantle an XJ-S door mirror? I've got two which are broken in different ways - on the first, the bottom of the retaining shaft has rusted away, meaning that the star-clip has dropped off and it won't stay where it's put, the other is intact except for the wiring which some idiot has snipped off right at the bottom of the retaining shaft.
If I could get them apart I could make a single working one, however, I can't even work out how to get the glass panel off without trashing it!!
Cheers for the replies!
Simon R.
Posted: Fri Sep 25, 2009 6:04 pm
by Linxman
Hi Simon
I have taken apart both the pre and facelift mirrors and although slightly different, they are similar in all the ways that make them both a devil to assemble and reassemble! It is just about possible if they are new, but once they have been on a car a litle time and water has got in, it can be very difficult indeed to do anything other than minor repairs due to the seizing of components, even ones which look externally perfect.
Hopefully though I can give you and others the benefit of my experiences, although it was some time ago so please excuse me if I am not 100% accurate. The following applies to the pre facelift cars.
First of all, the mirror glass, which you will see is mounted on a plastic mount. In the factory this must have been the last piece to go on, it is pushed onto clips behind the plastic mount which in turn connect it to the electric motor. I think you have 2 options here. You can either try to pull the mirror glass / plastic mount off the clips behind. Chances are you may well break the glass, but at least you have 2 chances I guess if you have two good mirror glasses? If you could somehow fix a rigid piece of wood or something to the mirror glass to stop it flexiing you may have more success with your prising and pulling.
Alternatively, you might be able to push the glass far enough up and down respectively to reach the 2 screws which hold the whole black plastic surround onto the mirror casing, including the glass, and then remove the whole section in one piece. They are not very accessable but you can just see them. I've done it this way so it is possible, if the screws are not seized in the mirror casing. But again there is always the chance of the glass cracking.
If you are successful here, you will then have full access to the innerds and will be able to see what you can do for yourself. I think that if you need to change the wiring over you would need to remove the plinth from the mirror casing. However, I think you will find that even in your good mirror, the area around the pivot is rusted due to water ingress. In particular there is a separate collar which when new you can just about remove intact, but on a used unit I think it will usually be more or less impossible. In other words, if you need to remove the mirror plinth from the casing this may be very difficult indeed, and even if you achieve that, it may be difficult or even impossible to get it securely back together again. And finally there is the very stiff spring under the plinth that you would need to push back and somehow, under pressure, secure that with the push on star washer - again a devil of a job without a special tool. Obviously that whole area is already rusted on one of your mirrors, but I guess you have a chance on the other one.
It is very frustrating to think but in reality your best route might be to find a decent second hand one. I have a spare pair somewhere so if you're stuck let me know which side you need and I'll try to dig it out.
Good luck!
Posted: Sat Sep 26, 2009 9:29 am
by poprivet
Simon, these pics may help you to see what is behind the glass. As Phill says, the glass carrier can be prised away from the locating balls but you can't get in there to lever it out as the glass is stuck on in the way. When I did mine, I warmed up the whole mirror carefully which softened the glue sufficiently for the glass to be removed in one piece.
There is one fixed ball and two others controlled by the motors. (Click on pics to enlarge).
http://www.jec-xjs-forum.org.uk/xjsbb2/ ... 6-1_tn.jpg
http://www.jec-xjs-forum.org.uk/xjsbb2/ ... 6-2_tn.jpg
Posted: Mon Sep 28, 2009 12:52 pm
by SimonR
Hi chaps,
Many thanks for those two really helpful and in-depth replies!
I'm at work at the moment but will read them through again when I get home and have got a mirror in front of me.
I'm not sure how much luck I'm going to have as I've tried to re-install a sur-clip (instead of a star washer) on the mirror what has still got an intact lip for it to fit behind and it's a real pain! What I've tried to do so far is wire the spring closed (while it's trapped in a vice) and then push the large surclip into place. I think I'm nearly there and if I could get the star washer on past the electrical connectors could probably tap it into place with a hammer and the correct sized socket. That's one of the reasons I want to get the mirror apart as with all the innards removed I can hopefully get the mirror body supported correctly so that it will survive being belted with a hammer!!
The reason I have taken the good mirror apart is that it's a series III XJ6 mirror that I bought off eBay when the seller advertised it as an XJ-S one.
They're NOT the same - the XJ6 has a different-sized bracket that screws onto the door.
The only other question I have is how do you get the little electrical connectors apart? I'm guessing that there's a special tool that slots over the pins so you can compress them and drop them out the back of the multi-plug...
If I'm at all successful then I'll post some pictures on the forum for others to use in the future.
Many thanks!
Posted: Mon Nov 02, 2009 1:10 am
by SimonR
Haha - I needed a working door mirror before I got around to dismantling my ones so bought one on eBay.
Apparently it was from a 1986 V12 and I was surprised that it had two extra wires for a heater element.
Were heated mirrors original spec on a v12 of this vintage...? I'm thinking it may have been a replacement one and therefore newer than the car.
Posted: Tue Nov 03, 2009 12:44 am
by chris211083
HI, yes the earlier cars didnt have heated mirrors. the first xjs only had one!!! one of my mirrors has done the same and the second one is going the same way, rusted on the rim. I currently restoreing my car so im going to buy brand new ones for the resto.
Re: Dismantling door mirrors
Posted: Sun Sep 24, 2017 10:50 am
by steve_m
Pop
Do you still have the pictures as they have disappeared off the website?
Which of the two toggles operates which mirror? There are a load of connectors in there and mine looks like it has been plugged incorrectly; the drivers mirror cabling goes through the door frame which doesn't seem to make sense as it appears to bypass the toggle switches completely.
Posted: Sun Sep 24, 2017 5:46 pm
by ptjs1
Simon,
the mirrors can be a real pain to dismantle and rebuild. BUT, it is possible with perseverance! See my thread here in the bodywork sub-section:
viewtopic.php?f=45&t=8223
If you read through the whole 2-page thread, it will probably answer most of your questions. Annoyingly, all the pics in my post on the second page which show the rebuild process have disappeared. However, I'll reload the pics for you tomorrow. To answer a couple of questions:
Yes- it is possible to separate a seized base unit to mirror head but it can be fiddly
Yes- it is possible to clamp down the spring and star washer to get it to fit in the groove but it's difficult! I tried lots of ways including lockwiring but it didn't work as you can't free off the wire. In the end I used a valve spring compressor and clamped around the whole mirror body (The pics will make more sense when loaded). If I was doing it again, I MIGHT remove the glass and motors and clamp it through the mirror recess. (The manufacturer must have done it this way and then assembled the motors and glass when built from new)
Yes- you can easily buy new star washers
Yes- you can separate the pins from the plug (on a facelift mirror) without a special tool. I'm sure it's also possible on a pre-facelift
As I said, I'll reload the pics tomorrow.
Posted: Sun Sep 24, 2017 5:54 pm
by poprivet
I think these were the pics:
I can't help with the wiring, I have a job remembering what I did yesterday lately! I have a feeling that the multi-connectors only go one way though
Posted: Sun Sep 24, 2017 6:35 pm
by steve_m
Thanks guys.
