Horn
Posted: Thu Jul 27, 2023 8:13 pm
by a_romeo_75491
Hello all,
Having had my 1995 XJS recently serviced, the mechanic commented that only one of the horns was working.
I've owned the car for almost 7 years and never knew any better. Can anyone confirm that the car should have two horns and how can I fix the issue?
Drive serenely
David
Re: Horn
Posted: Fri Jul 28, 2023 10:10 am
by PaulGover
David,
(a) There should be two horns - probably a legal requirement to ensure there's a backup.
(b) Look behind the front bumper. Check the wires. Get someone to press the horn button and listen to determine which horn is not working (you probably want earplugs or defenders or something!). If nothing is obvious, you can remove the horn and try wiring it directly across a battery - horns are simple: apply power, they should hoot. If not, AFAIR there's a set screw and locknut, and you can adjust the set screw to get the loudest noise (or none if it's wrong), but probably the coil will have burnt out. In the latter case, you can buy cheap replacement horns at Halfords or a motor factors or off the Internet. Halfords show some Bosch horns for a 1995 XJS:
https://www.halfords.com/motoring/car-p ... 68678.html
though IMHO a bit expensive and online-only ordering. The usual suppliers (Jaguar classic parts, SNG Barrett, David Manners, etc.) can almost certainly supply horns at a range of prices.
(c) Somehow you've managed to post in the XJS forums but not in one of the normal sections such as Electrics, which means the "Board Index" web page shows a red symbol against the XJS forum, but no green marker against any of the subforums, so people will miss your post. I'm not sure how to rectify this - whatever, I've given you an answer! But next time, whatever you did to create your post here, do it differently so it ends up in say the Electrics forum. (Sorry not to be clearer, but I've no idea how your post ended up in the main forum - I assumed that was impossible!)
Re: Horn
Posted: Fri Jul 28, 2023 8:39 pm
by ptjs1
It didn't used to be possible to post outside of the sub-sections, but the club did a software change some years ago and the problem arose and the club hasn't sorted it.
No moved to "Electrics"
Re: Horn
Posted: Tue Aug 01, 2023 10:10 am
by a_romeo_75491
Thank you gents...most kind.
Re: Horn
Posted: Tue Aug 01, 2023 1:47 pm
by poprivet
The two horns are pitched to make a dissonant sound. This makes an unpleasant noise more likely to grab attention. Also the two sounds are more likely to be heard with someone with hearing difficulties.
