Headlights on when connecting battery
AJT
Postby AJT » Sat Feb 28, 2009 9:13 pm
I was intending to start up my 92 Facelift XJR-S after its winter rest today.
It had been kept on an Optimate (with the battery still attached) as always throughout and kept in my garage.
However when I removed the Optimate I noted the green "charged" light was out. Thinking it may have blown the LED (like a couple of the other Optimates I have) I tried to start the car. ... battery totally dead
Throughout the day I have placed the battery on full charge with a conventional charger and reconnected the battery to the car.
Immediately, without even putting the key in the ignition switch the headlights came on, even with the headlight switch in the off position.
Any ideas?
I have tried putting switch cleaner in the headlamp switch on the indicator stalk just on the off chance.
Before I go looking for a faulty switch or earth fault has anyone else experienced a similar issue?
thanks
Alan
Postby Brakebuster » Sun Mar 01, 2009 9:43 am
hi,
that 'll be the headlight relay on the front crossmember over the radiator,
hope this helps
AJT
Postby AJT » Sun Mar 01, 2009 11:38 am
Thanks for your prompt response I'll take a look during the week.
It explains why the battery went flat during charging
I better look for a replacement
Thanks again
Alan
AJT
Postby AJT » Mon Mar 09, 2009 11:00 pm
BB, you were totally correct it was the Headlamp relay
3.60p from David Manners - Part number DAC7686
FYI the relay on my model was in the bank of relays to the left of the engine bay.
Thanks again for your help
Alan
ami8soulfood
Re: Headlights on when connecting battery
Postby ami8soulfood » Mon Jun 04, 2012 12:26 pm
Hi Alan
I know its been a while since this posting, and I don't know if you still have your cat and ae still active on JEC.
I have the same issue with my 1991 Facelift 4.0 Auto (UK registered). Trouble is there is a bank of 5 light blue relays labelled DAC7686 (still readily available via David Manners btw) on the forward LHS fuse box and there are so many different wiring diagrams out there which all point to a different relay controlling the headlights. Can you help?
Best Wishes - Grant
poprivet
Postby poprivet » Mon Jun 04, 2012 5:36 pm
Hi Grant, they do have a habit of changing things around don't they. One of the facelift owning guys may be able to help in more detail, in the meantime, have a look at
http://www.captainjaguarscathouse.com/E ... erence.htm
There may be something of help there, if you have a multimeter you should also be able to tell which relay is faulty, if not how about substituting each one in turn with a new one until the problem is located.
