radio and clock died
van833
Postby van833 » Sun Mar 24, 2019 1:10 pm
I have a uk spec 1989 3.6 XJ-S.
Fuse 3 seemed fine, though I changed it but to no effect. I have had the ski slope off and ...sadly there seems to be no fuse under there (I had been advised there might be). I have taken off the aerial relay and got the aerial to go up and down, so I guess that works.
Help please!
Van
Re: radio and clock died
Postby davidr » Mon Mar 25, 2019 9:55 pm
Hi Van - have you checked for power to the radio and clock units? Do you have power to the relevant fuse(s)?
van833
Postby van833 » Mon Mar 25, 2019 10:22 pm
Hi, yes there is power to fuse 3, which also is for the boot lights.
Van
van833
Postby van833 » Mon Mar 25, 2019 10:26 pm
There seems to be no power to the clock or radio. electrics are not mu thing really...
poprivet
Postby poprivet » Tue Mar 26, 2019 2:36 pm
There is at least one inline fuse but I can't remember where, might be behind the radio itself?
Electrics changed quite a bit around 88/89 when the Teeves brakes were introduced so don't necessarily take any wiring diagram you have too seriously.
Also after 30 years, it's possible that some diy changes may have been made :cry: Is it an original radio and does everything else electrical work?
