Trip computer back lights
Posted: Sat Dec 19, 2015 7:01 pm
by mgj11
Just wondering if anyone knows the part number and where I can get the bulbs that light the trip computer on my 1992 facelift.
Re: Trip computer back lights
Posted: Sat Dec 19, 2015 8:28 pm
by ptjs1
MGJ,
Are you talking about the illumination on the display or the illumination of the buttons?
Posted: Sun Dec 20, 2015 4:35 pm
by mgj11
both as one of the display bulbs has blown and one half of the buttons aren't illuminated
Posted: Sun Dec 20, 2015 6:20 pm
by ptjs1
MGJ,
The display bulbs are removable and should still be available from Jaguar for a few pounds. From memory, there used to be a problem with the parts catalogue and the part number quoted. I remember ordering one up with my dealer and, when comparing my old one with the new, discovered they were listing the wrong number. We then spent 10 minutes going through their system until we could work out the right number, but we got there in the end. My suggestion is to do this with your local dealer rather than ordering from Jaguar online, in case they still haven't updated the parts system (unlikely) and you have the same issue as did I. You'll also get a better price asking for some (JEC) discount with your dealer.
The button display is a different problem. There is a mini- bulb soldered into each end of the circuit board. So, you have to open the casing and carefully pull the circuit board then solder in new bulbs or take it to an auto-electrician or similar.
Hope that helps
Posted: Sun Dec 20, 2015 10:12 pm
by mgj11
thanks Paul
Posted: Mon Dec 28, 2015 6:53 pm
by mgj11
Thanks for info, got a led bulb from Maplins and soldered it to the Pcb, we have light :D
Posted: Mon Dec 28, 2015 8:44 pm
by ptjs1
MGJ,
Glad you got it sorted! What was the part number of the Maplins bulb?
Posted: Fri Jan 01, 2016 4:47 pm
by mgj11
Sorry don't know just asked the guy for a 12v led bulb, probably best to go for the super bright ones
