I have a 1988 XJ-S 5.3 and have had problems recently with the battery going flat. This may be because I don't use the car much at this time of year, in which case I might simply disconnect the battery when out of use. However, on removing the battery for charging, I see it is only rated at 50 amp hour, and the workshop manual stipulates 68 amp hour. Also, I am quite concerned that this appears to be a standard battery, no sign of any vents or pipes anywhere. Should I be worried ? Does this mean I have to buy a Jag Battery, no doubt at an extortionate price ??
Jim
Correct Battery type ??
You can do much better, and cheaper then a Jaguar battery. Useful tips here http://www.jec-xjs-forum.org.uk/xjsbb2/ ... highlight=
Pop
Pop
Over the last week I noticed the engine seemed to be turning a bit slower then normal when starting. I thought the battery was perhaps 4 or 5 years old so must be due for replacement but looking through my records, I last changed it 10 years ago! Definately time for a replacement.
I had one delivered to my door by http://www.tayna.co.uk/ fully filled, charged and ready to go at a great price. I ordered the Varta which has the vent in the right place, in fact it has vents at both ends which come plugged. I had to swap over the vent adaptor from the old battery, but its only a push fit.
Ready for another 10 years I hope!
Pop
Pop
- MARKPEARSON
i found euro car parts very good 75ah bosch silver maintenance free with 3 year waranty for £61.69 inc vat www.eurocaeparts.com
- MARKPEARSON
Re: Correct Battery type ??
Pop
My battery was starting to slow down on cold days after standing for a few days so I decided to renew it. Similar Varta from Tayna again at the same price it was last time, I can't argue with that, very pleased
Yup - I obtained a battery from Tayna for my XJS last year - very good service and price!
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
Past:
1985 E28 BMW M535
