Instrument Panel illumination
Tintin
Re: Instrument Panel illumination
Postby Tintin » Sat Apr 01, 2017 1:54 pm
Suggest you have a word with Gil Keane of Better Car Lighting. He is very helpful and what he doesn't know about Jaguar compatible LEDs isn't worth knowing.
Robbie
Daimler Sovereign S1 4.2 1971
manold99
Postby manold99 » Sun Apr 02, 2017 11:54 am
Thank you for your advise, will contact Better Car Lighting as soon as possible
navyatco
Postby navyatco » Fri Mar 02, 2018 11:17 pm
Hi all, I've just changed my '79 XJ-S's dash bulbs for LEDs, and have (possibly) 2 problems:
1. When I select L or R indicator, as well as the correct LED flashing, the other one gives a very quick (and not as full on) flash immediately after the correct flash. When I switched back to the original bulbs, the problem disappeared. Is this a fact of life with LEDs, or do I need a different one?
2. When do the seatbelt light, the brake light and the low coolant light come on? Are they supposed to be on at ignition? If yes, (and mine don't) then is it likely I've blown a (or a couple of) fuse(s)? I had a look at the ones under the driver's dash, and the fuses looked ok, but I didn't pull any to closely check.
In hindsight, I should've checked the normal dash light status before changing to the LEDs; I have tried switching back to the bulbs, but none of those 3 above come on with ignition or when engine is running.
All other dash lights seem to be working fine, as are the instruments.
Thanks, Ray.
Mackie
Postby Mackie » Sat Mar 03, 2018 10:57 pm
Gil Keane supplied mine. Really nice guy to get advice from. His stuff is on this site: http://www.exclusively-jaguar.co.uk/xjn ... g-upgrade/
Mac
Previously: 1989 V12 XJ-S Coupe
