Hazard flashers on a 1986 XJ-SC 3.6
DavidCabriolet
Postby DavidCabriolet » Sun Oct 18, 2009 8:34 pm
Externally the indicator/hazard lights work when the switch is activated but the green indicator lights on the dash do not light up, except when used in the turn mode. this has resulted in a failure at the MOT test. any ideas on where the fault might be?
Postby Brakebuster » Sun Oct 18, 2009 9:33 pm
i would imagine it would be in the hazard lights relay, as this will be separate to the turn indicator relay,
try replacing the relay for a know good one, this should either not change anything, or make it work
hope this helps
JED1961
Postby JED1961 » Mon Oct 19, 2009 9:30 pm
:shock: they dont flash on mine !!! just the hazard warning symbol in the warning light row does ......thats all thats required for a MOT pass :shock:
