Transmission failure light on
raymondcredie980
Postby raymondcredie980 » Sun Nov 15, 2020 7:04 am
I have an XJS Celebration Convertible 4 litre, the car has done a genuine 43,000 miles and i am the second owner. Around summer this year the transmission failure warning light came on. I have no reason to believe the transmission has a fault, it is working perfectly with no stiffness of the automatic gear selector, in all respects the car is just as it always has been - perfect. A phone call to the closest Jaguar Specialist (56 miles away) revealed that the most common cause of a false warning is a failing battery, upon having this checked it was operating under par, although having no difficulty starting, so i decided to change the battery which was done immediately but the warning light remains stubbornly on! Does anyone have further suggestions please on what may be the cause?
Re: Transmission failure light on
Postby ptjs1 » Sun Nov 15, 2020 9:49 am
raymondcredie980
A failing battery can indeed cause a spurious transmission failure light illumination as I experienced this summer on one of mine. However, you mentioned that you replaced the battery. So a couple of thoughts of where I'd start:
- When you replaced the battery how long did you leave it before connecting the new battery? Was it at least 15 mins?
- Have you scanned the car for engine fault codes? The transmission failure acts as a safety back-up for certain engine problems, in order to protect the car. Even if you cant get the car fully scanned, with a cheap £5 bluetooth obdII dingle abd a £3 phone software package, you could read any engine fault codes from the XJS yourself (everyone should have these useful items)
- When was the transmission oil and filter last changed? The ZF4HP24 box really likes clean fluid.
raymondcredie980
Postby raymondcredie980 » Mon Nov 16, 2020 7:53 am
raymondcredie980
Hi Paul, thank you for that. Yes, the battery was disconnected for more than 15 minutes because i took it to my supplier for disposal and picked the new one up at the same time, that would be minimum one hour. I had all fluids changed after the light came on, but that was a routine major service and MOT, not as a result of the light showing. I will follow the route of diagnostics i think. Thank you for your kind advice.
Raymond.
almcl
Postby almcl » Mon Nov 16, 2020 12:00 pm
Another possibility for this fault which I experienced a little while back, is a failing throttle position potentiometer. Sounds weird, but the gearbox uses the position signal from the pot and if it goes intermittent will throw a fault code.
Mine may well have been self induced following a slightly over enthusiastic use of cleaner in and around the throttle linkage.
Can't now remember where I got a replacement from, may have resorted to the secondhand market although Barratts list the part as 'special order'.
Al McL
