You'll be getting fed up with me soon!......stereo
paulfrost88960
Re: You'll be getting fed up with me soon!......stereo
Postby paulfrost88960 » Sat Apr 25, 2020 3:08 pm
Well as i sit here with a beer, i'm one happy bunny! Started stereo work early today, or at least i would have done, but i had left my lights on when i put her away in the garage, so a four hour delay until i could get her started! Anyway i took the time to work through the diagrams and my notes and put some new connections on the radio. Whilst i'm sure the car wiring is original, it was nothing like the diagrams for the XJ-S or the XJ6 even, so i decided on a best guess and ploughed on. Some time later, much to my surprise when i reconnected the battery and switched it on, i got music from the radio and the aerial rose up. Rather than fine tune it then i decided to fit it back properly and spend time later on it. Having finally cleared everything up i went back to it and found that now i get no sound! I thought probably a loose connection from pushing it back in, but then remembered that i'd isolated the battery whilst final fixing and probably needed to re-input the security code. Once i'd done that it was all OK so as usual with these things a tremendous feeling of satisfaction when it worked.
Thanks everyone for their help. when i get a chance tomorrow, i'll post a photo as it looks a lot better than the previous after market one to my eyes.
cafcpete
Postby cafcpete » Sat Apr 25, 2020 3:46 pm
Excellent result! Well done with sticking with it.
Just check that it lights up with the head lights and that it doesn't forget stations when turned off and you have won :)
1996 Jaguar XJR6(auto)
2002 Jaguar X350 4.2(auto)
davidr
Postby davidr » Sat Apr 25, 2020 5:01 pm
Well done Its a good feeling when you put it back together and it works! :D
paulfrost88960
Postby paulfrost88960 » Sun Apr 26, 2020 1:54 pm
Photo attached of radio in situ. I'll keep a note of which wires went where in case it is of use for anyone else in the future.
paulfrost88960
Postby paulfrost88960 » Sun Apr 26, 2020 1:55 pm
Oh, and yes it does hold the stations and light up with the headlights on so a real result.
cafcpete
Postby cafcpete » Sun Apr 26, 2020 4:40 pm
Very well done, I always like the OEM radios :)
paulfrost88960
Postby paulfrost88960 » Sun Apr 26, 2020 8:40 pm
it's a hell of a reach to turn the volume up though!
