Trip Computer Failure
dieselpower
Re: Trip Computer Failure
Postby dieselpower » Tue May 08, 2018 6:45 pm
It lasted a day. Not working again. So this is the scenario - you take out the computer unplug it, plug it back in and it works. The following day or so. It doesn't work. Bloody annoying.
dieselpower
Postby dieselpower » Thu May 10, 2018 9:14 am
Failed again. Ugh
davidr
Postby davidr » Thu May 10, 2018 1:35 pm
Have you tested the wiring loom for continuity? Maybe there's a break in a wire somewhere?
dieselpower
Postby dieselpower » Sun May 13, 2018 2:21 pm
Haven't done that. Got no idea how to!
poprivet
Postby poprivet » Mon May 14, 2018 8:15 am
There's not a lot of space behind the trip computer, I'm wondering if the cables have a problem where they turn a sharp corner. Maybe by pulling the unit out they straighten and connect again for a while?
dieselpower
Postby dieselpower » Mon Jun 11, 2018 4:18 pm
The problem is it works for a day or two then darkness. No computer. Flippin' annoying!
dieselpower
Postby dieselpower » Sat Jun 16, 2018 9:34 pm
OK chaps (and chapesses) I prized the sucker out again as it was dead and wiggled with the wires. Nothing. No life. Then I jiggled about with the cable that has an in line fuse and bingo it came to life. So, I opened the fuse holder and scraped away at the surfaces that made contact with the fuse. So far... so good.... will report back in a few days.
dieselpower
Postby dieselpower » Sun Jun 17, 2018 3:06 pm
Following day. Dead again.... I despair.
RichardSEL
Postby RichardSEL » Sun Jun 17, 2018 3:37 pm
Intermittent fuse. Change it.
Get (while you can) Maplins switch cleaner N62AN (not WD40 that's oil based) and spray all plugs / sockets open along route. You've then eliminated that portion of loom. I'm not familiar how your trip computer connects. If it's by printed circuit board connector then those printed connectors do oxidise. But don't scrape at them. Just the spray and a few repeated plug in / plug outs should clean those connectors sufficiently
Any help?
dieselpower
Postby dieselpower » Tue Jun 26, 2018 2:23 pm
Much appreciated RichardSEL, will follow instructions and report back. Watch this space...
dieselpower
Postby dieselpower » Wed Jun 27, 2018 2:46 pm
So, had a bit of time today so fiddled about again. Disconnected the inline fuse housing, replaced fuse with new. Re-connected. Computer worked. Came back to it 30 mins later.... It didn't work. I'd left the computer sitting on the front of the ski slope as I thought more fiddling may be required. Wiggled the fuse housing and the computer came on. So, I went to Halfords and got a new in-line fuse holder, fitted it using spade connectors and it still works...... time will tell.
dieselpower
Postby dieselpower » Mon Jul 02, 2018 2:37 pm
Still the same. Leave it a day, doesn't work. Disconnect the fuse (new), reconnect, works. Absolute mystery. Would like to add that before doing the fuse disconnection I pulled and juggled and wiggled everything in sight. No joy. Then, just disconnected the fuse, reconnected and bingo. Worked.
dieselpower
Postby dieselpower » Wed Jul 25, 2018 2:32 pm
I have a question: Can I replace my trip computer with one from a different model car with a different part number even though visually they look exactly the same? My computer is part no. DAC 2884 but I can't find one. I can easily get a DAC 3749 - but will it work?
dieselpower
Postby dieselpower » Wed Aug 22, 2018 11:52 am
Fitted DAC3749. Seems to work. Time good distance reading good. Lets see how long it stays functional!
