The lights on the instrument panel of my '91 XJS have just stopped working, along with the light that lights up the auto gear stick/shift. Anyone have any idea what might have caused this?
Milan.
Interior lights on instrument panel not working
Milan,
Welcome to the Bulletin Board!
You haven't said if your car is a facelift model or pre-facelift. If it's a facelift, I think that Fuse 18 in the LH fusebox controls the instrument and gearbox illumination. I would start there first.
Re: Interior lights on instrument panel not working
Thanks for the reply! I'll check that fuse to see if it's the culprit.
My XJS is (I think!) a pre-facelift - it's a '91 J-reg. I've only had it for a couple of weeks, after longing for an XJS for several years. The car has seen better days; the bodywork is a bit rusty in places, but hey, it's an XJS, and it's great fun to drive!
Milan
Hi and welcome to the Forum
You're an enthusiast after my own heart
"after longing for an XJS for several years. The car has seen better days; the bodywork is a bit rusty in places, but hey, it's an XJS, and it's great fun to drive!"
As long as it's going, enjoy and sort the problems out as you go, however, prepare your bank account for a major hit at some point
Very best Wishes
DH Dove
Very best Wishes
DH Dove
XJS Bulletin Board Moderator
davidchevin
Welcome Milan
I'm a new boy, too, and my XJS has a load of unlit bits in the dash - we'll just have to learn where to look
David
1990 XJR-S
1990 XJR-S
Well, would you Adam n' Eve it.... I opened up the fusebox and had a quick look, but as it was dark I didn't bother changing anything. The next day, the lights are all working again! I guess when I wobbled them about a bit I must have done something...
Telsmoneypit
If it's not the fuse it will be the "fibre optic source", which is a posh name for a normal bulb that provides light via fibre optics to the switches and heater controls. This can be found in a black cylinder (cilla black?) lurking beneath the ski slope.
I plan to change mine for a super bright white LED. Brighter light, little or no heat generated and longer life.
I have changed all the dash illumination for green LEDs and now I can see the clocks at night! The rheostat no longer functions but who wants a dim dash again?
Tel
Tel
XK8 Antigua blue (with issues)
2005 X-Type Sportbrake (Triggers broom)
2004 X-Type sportbrake, 1967 S type ..and my lost love..1990 XJ-S 3.6 coupe
