My newly acquired '89 XJR-S has developed a stalling habit!
It runs fine when cold, runs fine at speed, idles OK on the driveway with the bonnet open but the engine dies after a few minutes when idling with the bonnet closed or when driving at low speed.
I am picking up a new amp in the morning, but I wondered if anyone here has had similar problems?
Also, can anyone tell me the function of the two wires that run from the loom to the connector on the end of the ignition amp. The connector has a 1/4" and a 3/16" spade terminal, the smaller of the two I suspect carries the ignition pulses from the ECU (disconnecting it kills the engine), but connecting or disconnecting the larger one seems to make no difference to the running of the engine. It works either way.
Thanks and regards,
