Hi Folks
The electric fan on my 1989 v12 coupe has started to come on more frequently. I thought maybe some kind of cooling issue...however tonight after charging the battery, I switched on the ignition and the fan came on (stone cold engine). When I switched the ignition off the fan continued to to run. In the end I had to disconnect the battery.
What can be causing this..switch or sensor of some kind?
Many thanks
sbb
Electric fan
Electric fan
The fan is controlled by a relay and a diode pack. The intention is that once the thermostatic switch makes, the fan will continue to run until the temperature drops below the spec, even if the ignition is switched off.
If the fan runs with a cold engine, it could be the thermostatic switch, the relay or (bit more difficult to work out how) the diode pack.
The relay should be the second item back on the left inner wing bracket and the diode pack the third. The t'stst switch is on the rad itself.
There is another twist. Midway through 89 (at VIN 156988) the wiring was changed. Up until then the fan was wired to come on if the air con compressor was active. Trouble shooting without the circuit diagram depends on which config you have.
Al McL
