Aero screen bracket
Moderator:jBlackwell
NATONEIL
Aero screen bracket
Postby NATONEIL » Mon Nov 10, 2014 3:29 pm
Good afternoon chaps
The clamp bracket holding one of my aero screens broke the other day. The weld failed where the pin fitted into the bracket. Has anyone else had this happen and have you managed to repair it or should I just see if I can buy a new bracket from Roger.
Neil
Suffolk SS100 Jaguar
Honour the past, drive it today
lowebird
Re: Aero screen bracket
Postby lowebird » Mon Nov 10, 2014 5:58 pm
Hello Neil,
Glad to say that I have had no experience of this so can be of no help however, I will see Roger on Friday at the NEC, what if anything would you like me to ask him?
Reg
RoyC
Postby RoyC » Mon Nov 10, 2014 7:24 pm
Hi Neil,
No, I've never seen them used on anything else other than a Suffolk SS100.
They're certainly different to the "Brooklands"-type aero screens, which have wing-nut attachment to the side posts.
Roy
Roy
Suffolk Jaguar SS100
4jagsjohn
Postby 4jagsjohn » Tue Nov 11, 2014 10:41 am
Niel, I am not to suprised to here of your bracket failure.I have recently been driving around in normal use of the car with the aero screens off and only put them on for more special occasions. I have noticed a while back particularly with the passenger side screen that they shake a lot particularly on certain road surfaces and on bad bumps they shake really badly and I thought its only a matter of time before something breaks. I you want to send your broken bracket to me I will see if I can repair it for you. The only problem might be the chrome. I might be able to make one in stainless steel. Cheers John.
jagss100
Postby jagss100 » Wed Nov 12, 2014 2:29 pm
Hi Neil
I have never removed mine since I fitted them 17k miles ago and only use them very occasionally with the screen folded down
I have not experienced the shakes over bumps like John
I can only assume there was a flaw in the bracket
I have seen them for sale on the internet but sorry I cannot remember where worth a look if you can find the supplier may be able to buy just the bracket
2 Jags Dave
White Suffolk SS100
Green XKR
lowebird
Postby lowebird » Wed Nov 12, 2014 5:16 pm
There you go Neil,
Just as I suspected, what with your need for new tyres, your worn suspension bushes and now a broken aero screen bracket to say nothing of your patent exhaust bobbin fix, you just enjoy driving too much and too fast.
Let Sue have a go and you have a snooze !!!!!
Reg
( reclining 150ft up looking C.Wharf )
RoyC
Postby RoyC » Sun Feb 22, 2015 9:24 pm
Hi Neil,
I've just experienced the same problem with my offside aeroscreen. The weld holding the pin failed (actually, it looks more like metal fatigue). Fortunately, I had the main screen up at the time and was able to save it at 70mph (your honour).
Did you manage to get yours fixed or find a replacement? Or did you buy a new bracket from Roger?
Roy
Roy
NATONEIL
Postby NATONEIL » Mon Feb 23, 2015 10:29 am
Roy
I have been very remiss and have done nothing. The garden looks nice and the soft fruit is planted but the broken bracket is still broken. It looks like a fatigue failure and this week (it is car week this week, MOT on Friday) I shall get it off and ask my mate to weld it as a temp fix before looking at the problem further. The weld failed and so perhaps a stepped pin is needed to ensure there is more material.
Neil
RoyC
Postby RoyC » Tue Feb 24, 2015 9:48 am
Neil,
I have emailed Roger to see if he can supply a replacement, although I'm sure he's still in NZ at the moment, so I don't expect a quick reply.
Meanwhile, I'll just have to drive with the screen up or refuse passengers (I've swopped the broken O/S pin with the intact N/S one).
Roy
Roy
RoyC
Postby RoyC » Wed Feb 25, 2015 1:29 pm
Neil,
I've had a reply from Philip at Suffolk Sportscars. He is currently having a batch of the brackets made and will send me a replacement when they are ready.
If you would like one, contact Philip: theworkshop@suffolksportscars.com
Roy
Roy
RoyC
Postby RoyC » Sat Mar 21, 2015 12:49 pm
Update: received the new bracket today (the workshop call it a "pintle"). The pin has a knurled finish, which is much better than the original splines.
Roy
NATONEIL
Postby NATONEIL » Sat Mar 21, 2015 1:08 pm
Roy
How much did it cost?
Neil
RoyC
Postby RoyC » Sat Mar 21, 2015 1:56 pm
Gratis. :D
N.B. - they have changed the screw size slightly, so I had to drill out the pintle bracket's screw holes slightly.
Roy
Roy
lowebird
Postby lowebird » Sun Mar 22, 2015 6:12 pm
Roy,
That's good news, I have always found that the factory are very good at letting you have small bits and bobs gratis. Makes a nice change from the mainstream car makers. The high level brake light on my Beetle has failed and VW want £113.00 for a new one !!! They will fit it for free though !!!!!
Reg
