I can't figure out how to remove the top crash roll from my 1970 series 1. I have removed the four screws (2 under the crash roll and two behind the radio speaker) and the demister vents.
I can't figure out how to remove it. It moves a little bit, but not much. It feels that some additional tangs are holding it.
Do I have to lower the entire front facia?
How do I remove the top crash roll?
Re: How do I remove the top crash roll?
There are 6 screws holding the crash roll. Two in the speaker recess; one either end of the crash roll and two more in the centre (behind the centre fascia panel). Then, it should come free. Mike.
Thanks a lot for the info. I'll investigate tomorrow.
Arne
Arne
Thanks Mike for your excellent advice! Because of other projects I have not worked with my XJ6 series 1 again, until yesterday. You were quite right, there are two screws behind the center panel. These are not mentioned in the original workshop manual!There are 6 screws holding the crash roll. Two in the speaker recess; one either end of the crash roll and two more in the centre (behind the centre fascia panel). Then, it should come free. Mike.
