its strange, my floors are ' perfect ' compared to your boot section ??, but the front has almost rotted away,
the whole outer A pillar section is still available for around £130 , it compromises the whole pilar from the first wing bolt on the top under the screen, round the door aperature and down to the sill, it also had the door seal rubber channel in it , this channel is a seperate piece , the whole top inner wing has been replaced from the a pillar to the top of the headlight bucket, and the front section of the sill has been grafted in to complete the rebuild in this area,
the door hinges themselvs provided an accurate fixing to hold and shape the replacement panel to start with, after i cut out all of the rot ,
i was quite surprised to see that the jacking point allthough cosmetically rusted has not suffered structurely and the vertical tube is solid roght to the bottom, and just the ' cup ' on the underside needs repairing,
i have managed to buy a whole rear quarter section from the JHT for £84, they are still offering this discounted part for sale at the moment,
http://www.jdht.com/webapp/wcs/stores/s ... d=-1&top=Y
there are other parts like floor sections for £60 to,
i only needed the offside buttress section, so the rest will be saved for repair sections,
i think i have at least another 18 months of work before getting her to paint, which will be white again , with a genuine TWR kit ,
http://www.jec-xjs-forum.org.uk/phpbb2/ ... NGY-11.jpg
