Took a Blow-torch to my XJS...................
Postby Brakebuster » Fri Jul 23, 2010 5:05 pm
......but its not as bad as it sounds, lol
i needed to remove both lower suspension pans and remove the springs to drop the front sub-frame
and i broke one of the bolts on the other side, so this time i took my blowtorch with ' MAP ' gas in it to put a little heat into the lower wishbone to remove the four bolts ,
worked a treat , and no broken bolts, just got to undo the engine mounts and the sub-frame mounts, and its ready to drop out
