project XJS....IRS rebuild.......
Posted: Sun Nov 30, 2008 2:59 pm
it has taken me four months to complete this task on my project XJS , but oh
, it needed doing sooooo much...
deciding where to start was the problem, and how about tackling it on my own, yes, i did all this work on my own , firstly , the car went up on a set of very strong axle stands under the rear jacking points with the front wheels chocked, and a second set put under the seat belt mounts for added security and stability , this caused my first problem, as i couldnt then access the radius arms to unbolt them, so i cut them in half in place, lol, i got a pair of new ones to fit anyway....
so, here come the pictures, first of all you will see the original IRS in place and then once removed, i couldnt beleive how rusty most bits were, and all four springs were broken to , as well as totally shagged hub bearings and U/J's ,
this one is looking up onto the rear disc and U/J , and half-shaft , the springs on the right with the over-axle exhaust going through the picture , not pritty , is it , lol
http://www.talkphotography.co.uk/galler ... N2504s.jpg
http://www.talkphotography.co.uk/galler ... N2499s.jpg
this next one is after it had been pulled from the car , what a state.......
http://www.talkphotography.co.uk/galler ... N2523s.jpg
partially striped down with the lower wish-bones removed along with the bottom plate and diff brackets ,
http://www.talkphotography.co.uk/galler ... N2549s.jpg
the diff can been seen in this last one, and to be honest , this was the only real bonus of the project,
its a 2.88 power-loc limited slip diff , which i found out had been fully refurbished only ten years ago, and the car had been parked up since 2000 , the insides were in perfect condition..
http://www.talkphotography.co.uk/galler ... N2553s.jpg
http://www.talkphotography.co.uk/galler ... N2563a.jpg
http://www.talkphotography.co.uk/galler ... N2554s.jpg
the car is now up in the air for four months waiting for some new bits to be hung back into her
http://www.talkphotography.co.uk/galler ... N0132s.jpg
