Screen washer Not Functioning
Posted: Wed Nov 26, 2008 4:21 pm
by Rowsonk
The screen wash on my 1990 3.6 has stopped working. I believe the pump is on the resevoir under the drivers wing. How is the under arch plastic panel removed (is it clipped or screwed) I don't want to start levering and break stuff.
Also is the pump feed via a relay if so how can I identify the little begger.
Posted: Wed Nov 26, 2008 9:36 pm
by barryjagman
Hi.
To get acccess to the washer reservoir you have to remove the lower plastic splash panel. At the bottm edge there are two plastic nuts/bolts which hold the splash panel to the large undertray. remove these bolts.
The top of the splash panel is fixed to an aluminium panel about half way up with 4 plastic 'push fasteners' You can normally pull thes out to release the splash panel. If not, put your hand behind the panel and push from the inside! This should give acess to the two washer pumps. Sorry do not know about any relay but i will check wiring diagrams and let you know.
Best Regards, Baz
Posted: Wed Nov 26, 2008 10:42 pm
by almcl
Two fuses and a relay.
The relay is third from left, top row, left component panel. (Under pax side underscuttle casing.)
Both fuses are in the under bonnet area, left wing.
