Both my front speakers not working, both rear are OK.
Just wondering if there is something obvious I could check before taking off the door panels?
Front speakers
Dougie
93 XJS 4.0L Solvent Blue Coupe.
62 Range Rover Autobiography Sport
Re: Front speakers
If there are anything like the XJ the cable that goes to the speakers are notoriously thin and weak, I have just re made my connections both front and rear, some of the cable had snapped by the connectors.
paulfrost88960
Re: Front speakers
Yes they definetly are really thin. I've just had my stereo out and i was surprised at how fragile they appear. I would think though they are only likely to have broken at either end, so you could always take the stereo unit out first to check there if that's easier. In fact thinking about it, it would be unlikely both front speakers would stop at the same time unless there was an issue at the stereo, where the wires are quite close. Also if a later type connector at the unit, there could be a problem with it?
Re: Front speakers
If the head unit is an Alpine unit as fitted to most mid-ninties Jags then it could be partial failure of the head unit if the loss of both front speaker audio occured at the same time. My 1994 XJ40 suffered this whereby the unit would render the radio station in the LCD display (or CD) but no audio output from any speaker. Replacement of the head unit was the only option and I was very fortunate to be provided with a decent working unit fitted at one of the Breakfast meets at AV8 @Keemble some years ago by Vince.
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
Past:
1985 E28 BMW M535
Re: Front speakers
Hi Guys,
Many thanks for your assistance will have a look at the weekend
Doug
Doug
Dougie
