cruise control
Johnscotty22
cruise control
Postby Johnscotty22 » Wed Oct 03, 2018 11:39 pm
hi there,
my cruise control has stopped working. it was fine then stopped working suddenly. any ideas? Regards Scott
steve_m
Re: cruise control
Postby steve_m » Thu Oct 04, 2018 7:19 am
It could be a loose connection or a leak from the bellows amongst other things.
Re: cruise control
Postby davidr » Thu Oct 04, 2018 7:20 am
Hi Scott - it would be helpful to know some more details about your car as there are different systems.
For example, earlier V12 cars had the econocruise system and the usual culprit is the bellows in the vee that actuate the throttle. This seal between the end plates and the rubber bellows breaks down. Taking it apart and resealing with some silicone will usually do the trick. Otherwise look for a vacuum connection that has perished or fallen off.
Later cars used the Kliekert system and the usual fault there is the dump valve sticking open.
Hope that helps
PaulGover
Re: cruise control
Postby PaulGover » Thu Oct 04, 2018 11:14 am
For later cars, another failure mode is perishing/wear of the silicone washer that links the bellows pushrod to the throttle linkage.
Johnscotty22
Re: cruise control
Postby Johnscotty22 » Wed Oct 24, 2018 10:54 pm
Thanks, sorry its an 89 v12.. turns out it seems to be a loose connection on the throttle cable sensor..
Thanks again
