Opening boot
Lodgie
Opening boot
Postby Lodgie » Wed Oct 04, 2017 5:15 pm
Got an odd problem with getting into the XJS boot - I can't. It's a 94 car, all central locking is working fine, the solenoid on the boot is clunking ok but the release lever underneath won't budge. I have 3 of the black Ford type keys which go in ok vertically and will turn 90 degrees clockwise but will only come out vertically. None will turn anti clockwise from vertical. I get the feeling I am missing something obvious and being amazingly stupid. Had this one for 2 days now but have had four pre-face lift ones before.
Any hints gratefully accepted ...
ng4xjs
Re: Opening boot
Postby ng4xjs » Thu Oct 05, 2017 9:44 pm
Try turning the key on the boot lock before unlocking the rest of the car. Not sure if the "valet" keys were still used on the facelifts.
Nick
Lodgie
Re: Opening boot
Postby Lodgie » Fri Oct 06, 2017 9:58 am
That didn't work Nick, sad to say. I made an error on the previous post, the key goes in horizontally, not vertically. May need a locksmith to sort this...
John Lodge
S3 Sovereign in Antelope and facelift XJS 4.0 Goodwood Green
Re: Opening boot
Postby ptjs1 » Fri Oct 06, 2017 12:18 pm
Lodgie,
You need to start by ensuring that the boot lock is in the position where it can be operated via the lever and locked / unlocked via the remote. The procedure is in the handbook but not very inituitive. See this thread here for some more details:
viewtopic.php?f=39&t=6308&p=29750&hilit ... ock#p29750
Lodgie
Re: Opening boot
Postby Lodgie » Sat Oct 07, 2017 12:55 pm
[pic=][/pic]Thanks Paul
This is getting interesting (read infuriating!) followed the instructions but no-go.
I have three ignition keys, all look the same and all operate the glovebox so I reckon there are no valet keys there. All three operate the ignition without a problem.
However, when it comes to the boot lock, the lock is set at the 3 o/c position and the keys will not pass the 12 o/c position unless a lot of fiddling and even more luck is involved. I've twice (out of loads of attempts) managed to get past 12 to 9 and back to 12 and remove the key but the boot stays locked regardless of whether the car was locked or unlocked. If I switch it back to the 3 pos, I cannot get it past 12 again. I am thinking the barrel may be shot and a locksmith required. I've oiled a key and left it in the lock. We shall see ...
John Lodge
Re: Opening boot
Postby ptjs1 » Sat Oct 07, 2017 2:37 pm
John,
When the boot lock is in the fully-locked position, the lever can not be pressed. So, irrelevant of the key position, is the boot lock lever able to be depressed? If so, but the boot can't be opened, then it feels like the micro-actuator is not being fired by the central locking or else the lever connection has broken. If this is teh case, you might have to revert to drilling a hole in the bootlid to access the control. Let's hope this isn't the case yet.
If however the lever is in the locked position and can't unlocked with the key, then it could be a problem with the cylinder operation. The cylinders can get jammed. When I had a problem, I actually managed to turn the key slightly and then carefully pull out the whole insert with the key. You may find that this will work.
Lodgie
Re: Opening boot
Postby Lodgie » Wed Oct 11, 2017 11:14 am
Update ...
Been to a locksmiths, much sucking of teeth and hmmming, concluded that the barrel is broken. They're going to order a Tivo lock pick (don't get many of these mate) and a rebuild kit. £135 plus VAT.
John Lodge
Re: Opening boot
Postby Brakebuster » Wed Oct 11, 2017 12:12 pm
did you try ' bouncing the boot lid ' while cycling the central locking, this can sometimes make a lock work if a sticking issue
never heard of a lock barrel break ? just gum up
hope it is the right solution
Lodgie
Re: Opening boot
Postby Lodgie » Wed Oct 11, 2017 12:44 pm
Did try the bounce boot. The locksmith was fairly convinced it was a barrel problem, I'd used oil and plus gas plus a few other chemicals to flush it out. The key wold turn 90 degrees from 3 to 12 and very occasionally with much fiddling from 3, anti clockwise to 10ish. Something is mechanically amiss in there!
John Lodge
Re: Opening boot
Postby ptjs1 » Wed Oct 11, 2017 1:44 pm
John,
If the barrel is at fault and in the locked position, then you won't be able to depress the lever. Is that the case? If you can depress the lever, then I would suggest you have a different, or additional, issue with the lock lever wire or actuator switch.
Lodgie
Re: Opening boot
Postby Lodgie » Wed Oct 11, 2017 4:09 pm
The lever is immovable, solid as a rock...
John Lodge
Lodgie
Re: Opening boot
Postby Lodgie » Wed Oct 25, 2017 4:56 pm
Update time. The locksmith failed to open the boot do trundled off to our local “real” garage, Hawk at Battlesbridge, Essex. They drilled a hole behind the number plate and got the thing open, it seems that some stuff had been disconnected that shouldn’t have been and then some shut the boot. Now to get the lock rebuilt ...
John Lodge
