Nice research, DH!
If I ever get done with the winter rebuild of my 6 cylinder Daimler, this will be the next project.
Code a Replacement Remote Fob XJS
Al McL
Excellent information! Just what this forum is all about.
Pop
Pop
Good idea, I have stripped both my old fob and replacement and at least have found them to be the same, so I have the right one. However the button is damaged on the board...must admit I am tempted to de-solder and replace it.
Swopping the switches would be a good fix, but........I think that if the battery power is removed from the fob for more than about twenty seconds the fob will lose its coding.........thus you could end up back where you started.
DH Dove
DH Dove
XJS Bulletin Board Moderator
pauljbanfield
Re: Code a Replacement Remote Fob XJS
Hi - we have a 1993 XJS 2+2 convertable.
Having managed to get hold of a new fob and a blank key.....luckily we have a spare key....the programming of the fob seems to be a mystery!?
We have tried the methods suggested on previous posts - but none of them seem to work!
Is anyone able to help please?
Thank you
Thank you
I only found one that works on my '93 coupe. Instructions about disconnecting the battery &c are for the earlier 19K system and don't work on later systems. The later, factory fitted system, which is identifiable via the Jaguar badged security module fitted below the right rear light cluster, needs a different approach.
The first step was to locate the 'security enabling harness' under front of the glove box. Did you find this?
If so, then you may need to rig a switch because the system has to be toggled 4 times within 5 seconds to put the system in to learning mode and I wasn't able to do this quickly enough with a paper clip. It was also necessary to do it in a quiet, closed garage as the initial short beeps were pretty quiet (even with my hearing aids turned up).
The sequence which worked was
1. Turn ignition key ON.
2. Turn security switch OFF (closed circuit).
3. Turn ignition key OFF.
4. Turn security switch ON. (Open circuit)
5. Cycle security system switch ON/OFF rapidly 4 times (within 5 seconds). Leave it on when a series of short beeps occur
6. Press each transmitter in turn until a total of 5 confirmations are heard.
Al McL
Further to Al's helpful advice, I think you can also force the reset on that system just by toggling the valet switch in the centre console.
If you don't have a valet switch, the wiring for it is under the lining of the centre console. Remove the lining and you should see a 2-wire plug. AFAIR one wire is purple? Use a paper clip and bridge the wires to toggle it.
