Auxiliary/ Extra air valve
richard.whittington
Postby richard.whittington » Sat Mar 28, 2020 10:28 pm
Hello All
Unfortunately I have misplaced or lost my auxiliary/extra air valve control screw.
The part no. Of the air valve, which includes the screw is EAC 2773, that was fitted, I believe to the XJS HE.
To buy a replacement valve would be quite expensive , when all I require is
sufficient information for me to buy or make a replacement screw.
Any assistance would be very much appreciated
Kind Regards
R Whittington
davidr
Re: Auxiliary/ Extra air valve
Postby davidr » Sun Mar 29, 2020 11:59 am
Hi Richard - I have an AAV that I cut up for an autopsy and subsequent magazine article that we published in August 2018. Why? Well if you leave a bloke alone with a disc cutter its inevitable!
Here are the parts that I cut up.
I have a thread repair kit which as well as its obvious job is also very useful for working out a mystery thread. This kit is not very expensive and its one of the most useful things in my workshop.
The idle screw has a peculiar thread. Its very close to 1/2" UNC but binds up after a few turns. Its closer to M12 x 1.75 but again binds up after a few turns so I'm not sure what it is.
So I fear I've not helped you much. Of course ,what I do have is a spare idle screw and you're welcome to that if you send me your address. You can either pm me here or my contact details are in the masthead of the XJS section in the magazine
PaulGover
Postby PaulGover » Sun Mar 29, 2020 3:43 pm
According to Kirby Palm's book
On this author’s ’83 (as well as in the photo), the adjuster is a 12mm thread with a head barely larger than the threads, so
the head requires a 13mm socket to fit. However, Craig Sawyers reports that later versions (including replacement
valves to fit earlier cars) use a metric threaded adjuster with a much larger head: “The old one is indeed metric, M12,
but metric fine thread. It is however a special, with a 13mm AF head (standard is 19mm AF). New valve 12mm over
the threads, 1.75mm thread pitch and 19mm AF. That is a standard metric M12 bolt. Truly huge by comparison.
Jag/Lucas have clearly economised by using a standard M12 coarse thread bolt with the standard head. Adjustment
sensitivity with the coarse thread is just fine.”
What's really annoying is I had a broken one I could have measured sitting on the shelf and only threw it out late last year.
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
steve_m
Postby steve_m » Sun Mar 29, 2020 5:03 pm
I threw an old one out last month!
richard.whittington
Postby richard.whittington » Sun Mar 29, 2020 9:25 pm
Great news
Do you think that you could find it?
steve_m
Postby steve_m » Sun Mar 29, 2020 9:37 pm
Yep, it's in the metal bin at the recycling centre.
Which is unfortunately closed for some strange reason otherwise I would be straight over the safety rails and straight in there.
Wouldn't be the first time.
Last time got a really lovely rock for the garden.
richard.whittington
Postby richard.whittington » Sun Mar 29, 2020 9:42 pm
I think that continuing this conversation may get one of us into trouble bye
davidr
Postby davidr » Sun Mar 29, 2020 9:49 pm
The pictures I took were today. That screw is sat on my workbench. Yours if you want it.
steve_m
Postby steve_m » Sun Mar 29, 2020 9:52 pm
Jeez, lighten up.
richard.whittington
Postby richard.whittington » Sun Mar 29, 2020 10:10 pm
Sorry Steve, no offence intended
K Regards
RWhittington
steve_m
Postby steve_m » Mon Mar 30, 2020 9:47 am
None taken; anyway, that was in France where they are much more lax whene it comes to Health and Safety!
