Code a Replacement Remote Fob XJS
Recently bought a replacement remote fob for a 1994 XJS, how can I code the car to recognise it.
Pstocks
Hi and welcome to the Bulletin Board.
My understanding is that the fob is programmed to the car and this can be done by main agent, cost last time I enquired approx. £25.00. I guess other people can do it if they have the right kit.
BTW I have been trying to buy a new fob but was told Jaguar Clasic Parts are out of stock - did you buy yours secondhand?
Does it match the original? (there are at least two similar looking fobs which are slightly different in shape/size and have the attachment point on opposite sides at the top when viewed with the button face up).
Best Wishes
DH Dove
Best Wishes
DH Dove
XJS Bulletin Board Moderator
I don't suppose its one of these? Listed on the JEC e-Shop > Car Parts > Misc. Parts & Sundries page.
https://vault2.secured-url.com/jec-dire ... AG-FOB.jpg
Jaguar Key Fob
We have some old stock Jaguar Key Fobs
Part number on the back "LJE2610-BB"
We would recomment the batterys be changed before use.
RRP About £99
Price: £20.00
Pop
Jaguar Key Fob
RRP About £99
Price: £20.00
Pop
Pop
No, like this.........
http://www.jaguarclassicparts.com/webap ... y_rn=12852
But with the attach point on the other side, I think it's 418MHz.
DH Dove
DH Dove
Got it off ebay, they do come up from time to time, there have been 2 or 3 in the last month....including a new one. They go for between £45 - £60.
I have had bits of instructions regarding recoding, takes about 2 mins apparently no special tools required.
It is the single button one in black with gold bezel.
Erm, you may be referring to the new one I bought off e-bay in the past week or 2 - cost £62 + £4 p&p (part DBC10085). This was after cancelling my order with Jaguar as on back order for too long (that was for part DBC100852). Apologies if I trod on anyone's toes...
Also bought a key from Jaguar for £35ish pounds.
Now need to get both coded, as they are useless lumps of plastic currently - so far been to Jaguar in Brentwood, Essex and Jaguar in Amersham and neither have the right equipment...phoned Jaguar in Ipswich and they advised they might be able to do it (probably for £50ish pounds!) but I'd need to take the car in so they could check....surely it can't be this hard??
Richard
kevinhafner
If you're willing to travel I've just had mine done at the Canterbury main dealer, Barratts, on my 93 convertible but it took a while as they had to make sure the machinery was working properly.
If I can help any more please e mail.
Kevin.
Kevin.
On my 1993 XJS, the remote fob is programmed in the following way
1. Record radio security code (if so equipped).
2. Disconnect negative battery terminal/cable.
3. Reconnect negative battery terminal/cable; "beeping" should be heard.
4. Press each transmitter so a total of 5 confirmations are heard.
5. Test operation. Enter radio code (if needed). Set clock.
(You may need to disconnect the security system back up battery)
For a later model, and I am not sure when the change was implemented, the following method sometimes works
Remove the lid and tray from the center console, and see if you've got a
connector in there. It's a small black connector with a yellow/white wire
and a black wire. Stick a paper clip in each of the 2 active holes. Shorting
the 2 wires is the equivalent of the XJ40 Security switch being in the OFF
position. An open circuit equals ON.
1.Security ON
2.Ignition ON (accessory)
3. Security OFF
4.Ignition OFF
5. Toggle security ON and OFF until you hear a series of shorts beeps begin
(approx 3 times), then leave it ON.
6. Press the button on one remote, then the other. You will hear a loud
confirmation beep after each press. Keep alternating like that until the
confirmation beeps stop. (Approx. three times, I believe.)
(At this point, you may get an error beep, similar to a door ajar warning,
when attempting to lock and arm the car. The following steps appear to
complete the process.)
7. Security OFF
8. Press one remote. The doors will lock, but the alarm will not arm. Press
it again. They will unlock.
9. Repeat step 7 & 8 with the 2nd remote.
10. Security ON.
1.Security ON
3. Security OFF
4.Ignition OFF
7. Security OFF
10. Security ON.
kevinhafner
That's interesting, I didn't know that could be done. I know I can't ask for your vin but is your '93 a full facelift (2+2, MY 93.5)or a or a pre May (MY93) facelift?
Thanks, Kevin
Thanks, Kevin
I tried the first one and don't get beeps on reconnection of the battery which could be because I need to find and remove the alarm backup battery....do you know where it is.
Went on to the second suggestion looking under the centre console and found the wire mentioned, however no number of toggles ON and OFF would produce the beeps.
On my car there is a alarm indicator light next to the lighter...this came on the other day not sure how or why but went off went the ignition was switched off / on.
regards, Paul
1994 XJS AJ16
regards, Paul
1994 XJS AJ16
Paul/Kevin,
My car is pre 93.5, date of first registration is April 1993, and is not a 2+2.
VIN is 185577.
The back up battery for the security system is located in the boot, behind the trim for the right hand rear light cluster, just behind the aerial housing.
Its not easy to spot, but if your car has the same security set up as mine, there will be a small black box secured with 2 x 8mm nuts. This small box houses the movement senser for the alarm system. If you remove this box, behind that will be another small black box which contains the back up battery. The original battery was a 6V 0.5Ah sealed unit.
However, I believe the latter cars did away with this battery.
If you think your car has the same system as mine, I have a PDF copy of the security manaul which I can email to you
VIN is 185577.
Many thanks to Nigel for his most interesting information.
I have had the central glove box out on my vin 188259 coupe and there's no socket:
http://www.jec-xjs-forum.org.uk/xjsbb2/ ... 5-1_tn.jpg
there's no switch, either.
The key fob has its part no clearly listed (and is a 318Mhz one) but this is NLA according to the Jag classic parts web site.
http://www.jec-xjs-forum.org.uk/xjsbb2/ ... 5-2_tn.jpg
One of the inependents suggests that this part supersedes to the DBC10084/2 but this isn't supported either in the parts cat or the classic parts web page, which suggest it was for use with cars after VIN 194774. All in all there are 3 change over points listed just for facelifts, very little documentation, multiple country versions and a lack of spares.
Oh joy!
Oh joy!
Al McL
According to the parts manual, 318Mhz system was for USA market, 418Mhz was for UK
Pulled the black box out but cannot see a backup battery. The module is a Security Electronic Control Module DPP 1051/XX Programmable Part. Disconnected all leads inc main battery, on reconnection no beeps from the alarm.
Any more guidance / ideas would be appreciated.
Dear All
Well I solved my own key fob problem today and have done some research in the hope of clarifying this puzzling issue tho to be honest I'm still a bit confused, anyway here goes.......
My problem was the classic "push button hinge broken" thus stopping the button that you push from activating the button on the pcb underneath. A previous owner had helpfully drilled a couple of holes in the cover as well so that you could stick a biro or similar in to push the pcb button
Recently I spotted an advert on e-bay for a "jaguar key fob transmitter DBC 10085 case only". I won this item and this morning received a brand new case in a genuine jaguar bag. I dismantled my own fob (418MHZ) and transferred the innards to the new case fitting a new battery at the same time........RESULT
Confusingly the bag was printed with the part number JLM 20234 - it would appear that at some point when so many of the buttons were breaking Jaguar decided to produce the case only and allocated this part number to it.........don't expect to trace it though as this info was only released to dealers (many thanks to Graham at Grubloggger once again for that nugget of info.)
This case is the same for DBC 10084 and DBC 10085 fobs, I have e-mailed the seller and asked if he has further stocks (£19.95). If he has and a broken case/button/hinge is your problem then this is the way to go.
Having studied the relevent page in the parts manual I think that the information it contains is contradictory (surprise, surprise). If you look at Security Control Module (in the boot) it implies that all UK XJS's were fitted with 418 MHZ systems, but the remote fob info refers to both early 318 MHZ (DBC10084(2)) and late 418 MHZ (DBC10085(2)) systems. Since almcl's fob is clearly marked as 318MHZ I think the latter is the case.
The 318MHZ fob is part no DBC 10084(2) and is apparently still available from Jaguar Classic Parts as this link at £67.88.
http://www.jaguarclassicparts.com/webap ... gory=21555
(NB despite my earlier post above the DBC 10084 and 10085 fobs do seem to be physically identical, sorry. There is yet ANOTHER key fob of slightly different dimensions, more square, with the hanging tag on the other side which has a different button design with no hinge, one screw only in the rear cover and also appears to be numbered DBC10085...........I cannot explain this at present
The 418MHZ fob does not seem to be currently available anywhere apart from secondhand on e-bay etc.
However......this is solid state technology and unless it has been crushed I suspect that any non operation is due to a mechanical problem, ie hinge/ button broken, or, flat battery/ poor battery contact - the contacts are very weak and not really held in place by much apart from the case. A new battery and judicious cleaning and contact bending may well solve the problem, or if broken, a new case.
Whilst I realise that this does not progress the problem of re-programming the things I hope that this sheds some light on the problem
Best Wishes
DH Dove
Best Wishes
DH Dove
