CHANGING HEADLAMP BULBS
I have a 1986 5.3 Coupe which is fitted with headlamp wash/wipe. One of my headlamp bulbs has blown so I am going to replace all the bulbs. Are there any precautions I need to take when removing the wipers so as to gain access to the retaining clips so that I can remove the headlamp to change the bulbs, can I manage it by just releasing the chrome surround or is there a way in through the wheel arch??
1986 XJS 5.3 V12 COUPE
Re: CHANGING HEADLAMP BULBS
Remove the front splash guards under the wings which will give you access to the rear of the lights through a hole in the rear of the headlamp housing.
Hope this helps
Hope this helps
1986 3.6 MANUAL (WAHOO FINISHED FULL RESTORATION!!!!!!!!!)
1998 MK IV TOYOTA SUPRA TT VVTI
LIVING THE DREAM
LIVING THE DREAM
Many thanks for that. I didn't fancy having to take the front of the car to pieces!!
I also found it helpful to jack up the side of the car that I was changing the bulb on and turn the wheel outward - gave a bit more arm space; a friend with another facelift model advised me to take the wheel off, but I found just jacking up to be enough, otherwise squeezing around the tyre is a bit of a nadge. Might be different with the pre-facelifts of course.
Richard
If you have not already changed your headlamp bulbs it would be a good idea to look into replacing them with some of the newish Phillips ones which while still being 60/55 watts give about double the output of normal bulbs. I replaced my '94 coupe ones with them and the illumination from the standard rectangular lights is transformed from just adequate to superb. Since then Phillips have brought out a later design which will no doubt be better still. They are called X-treme Vision and can be got on-line at powerbulbs.com in Wakefield who do an excellent service.
1994 Coupe AJ6 engine
