Steering wheel color
FinPlanMan
Postby FinPlanMan » Fri Mar 09, 2018 8:02 pm
Doing some restoration on my 2006 X-Type. Interior trim code is "NED". I have online sources to buy a new steering wheel but the colors are confusing. Anyone know the leather color of this wood/leather wheel?
Re: Steering wheel color
Postby davidr » Fri Mar 09, 2018 10:33 pm
NED is Ivory but I doubt that's the colour of the steering wheel.
If you could post a picture we might be able to help a bit more
FinPlanMan
Postby FinPlanMan » Mon Mar 12, 2018 12:26 am
This is the first time I've tried to post a picture. Not sure if it is set-up properly.
2006 X-TYPE STEERING WHEEL
Postby davidr » Mon Mar 12, 2018 12:41 am
Hi - not sure what colour that is. I was half expecting it to be Warm Charcoal (LEG) but that's not what you've got. I have a brochure somewhere and I'll see if that gives any clues.
By the way, if it were me I would strip and recolour the leather. I'm assuming that the wear on the leather is the reason you'd like to change it? It could be that retreating the leather may be much easier and cheaper than replacing the wheel?
FinPlanMan
Postby FinPlanMan » Mon Mar 12, 2018 1:28 am
Thanks. I’ve checked with upholsterers here in Houston, Texas & the cost of refurbishing would be close to that of a new wheel. Also, I’m told that there would be no guarantee of success. I plan on keeping the car indefinitely so a new one seems the logical choice. I just want to get the correct one.
BrizzleJag
Postby BrizzleJag » Tue Mar 13, 2018 4:24 pm
You can buy kits online. I got one from Amazon last year and it's fairly easy to do with a little care and testing with mixing the right colour. The kit was only £15 great results and still looks good now.
FinPlanMan
Postby FinPlanMan » Wed Mar 14, 2018 4:19 pm
Many thanks. I'll research that. I'm still trying to determine the name of the color.
Postby davidr » Wed Mar 14, 2018 9:38 pm
Sorry - I said I'd look it out for you in a brochure I have from the period but I forgot to look and now I'm away on business.
I have recoloured steering wheels before and got very good results. It just takes care and patience. I'd suggest looking at www.furnitureclinic.co.uk which has some useful guides on how to repair leather and also sells kits with all you'll need to do the job yourself.
As I say, it can be done with care and patience and it's also very satisfying!
David
Postby davidr » Sun Mar 18, 2018 9:47 am
I've now dug out the brochure I kept from when I bought one of these cars new in 2009.
As you see from the picture below of the standard trim combinations, Ivory (NED) leather came with Oyster (AMT) fascia and the steering wheel would be the same colour.
Here's a picture of the relevant pages in the brochure. Please bear in mind that this is a UK spec brochure from 2009 and yours may be different.
Furniture Clinic do supply a leather repair kit in this colour
Hope that helps
