Dash fault
JagLady1
Dash fault
Postby JagLady1 » Thu Apr 09, 2015 11:17 am
The electronic Dash on my 1989 XJ40 Jaguar Sovereign has failed it was working fine displaying all the indications, however the fault display on the right hand side was flashing up continuously with all sorts of warnings. I took the dash apart and checked the Capacitors one had failed. I replaced the capacitor and dash but now it does not work at all. Is there anyone that has had a similar experience or could offer some help?
robv12
Re: Dash fault
Postby robv12 » Thu Apr 09, 2015 4:43 pm
sadly an all to common fault on early XJ40
possibly the way round it is to source a used dash pod and swap the whole thing over
sorry but I cant see where you are based, but it will also be worth a call or visit to David Marks in Nottingham as he is our technical advisor on these cars, David will be able to help
http://www.davidmarksgarages.co.uk/
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
naki
Re: Dash fault
Postby naki » Wed May 06, 2015 3:48 pm
agree, very common fault on the few surviving 3.6 XJ40.
I have not tried it myself yet (only a matter of time though), but i have heard some people have managed to revive the dash display by resoldering the entire unit. takes patient and some soldering skills. nothing to loose by having a go?
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 3.2S-4.0S Man conv
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
96 X300 Daimler Six LWB
97 X300 Sport 4.0 Manual
00 LR Discovery 2 TD5 ES A
03 X350 4.2 XJR
JagLady1
Re: Dash fault
Postby JagLady1 » Wed May 13, 2015 6:01 pm
Still trying to sort out the issue with the Electronic dash with no success so have bought an analogue dash direct swap as I thought all the connectors are different. Has anyone attempted this swap if I cut off the electronic dash electrical connectors and join the same colour wires together, is the wiring loom colours the same so that the analogue dash will work?
naki
Re: Dash fault
Postby naki » Thu May 14, 2015 1:32 am
am not sure its as simple as that.
i have heard of one owner managing this but its takes significant electrical skills to mate everything up. far simpler to resolder the original unit.
i would suggest trying to find an electronics repair shop, that do computers/ TVs etc, maybe they will be willing to take it on?
Am not sure where you are based, but an internet search might yield some local shops that could help?
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
03 X350 4.2 XJR
robv12
Re: Dash fault
Postby robv12 » Thu May 14, 2015 9:02 am
oooh noooo, DO NOT try and do this, Digi dash and Analogue just will not swap over, the electronic architecture of the two cars is completely different, and, as a first question to get an answer to, is in fact the dash pack that is causing the issue, or something else in the working of the car, seems odd that nothing is working at all, is power in fact getting to it at all??
There was a guy breaking an early car, I will dig about and see if I can find out who it was and be back later if I have some sucess
robv12
Re: Dash fault
Postby robv12 » Thu May 14, 2015 9:07 am
try here, look for post by Stan Spence, he has a 100% perfect one for sale, or at least did have
https://www.facebook.com/groups/2382853472/
JagLady1
Re: Dash fault
Postby JagLady1 » Fri Jun 26, 2015 10:42 am
Good News I have sorted my electronic Dash issue but it was buying a working replacement. This is not the ideal as eventually I am sure this one will also fail. If anyone is interested I have 3 non working electronic instrument clusters if anyone wants to repair them?
