Headling undermaterial
Posted: Sat Oct 20, 2018 10:07 pm
I am looking to strip and replace the headlining on a Daimler mk2. However, the under material that is glued to the rook seems to be a hard foam material and, I am having trouble sourcing the material. I have been told to buy a material with a foam attached (2-5mm) from a Martrim. It seems to have been used on later vehicles. Does anyone know the hard under material I am needing and where can I purchase it.
If I can source the material, I would assume it would come in a complete sheet as it seems to be a material that would not be able top roll-up. if that is the case, would I have to take out the rear/front window to attach the material?
All help and advice gratefully received.
