Glove box lock
PaulHaskey
Glove box lock
Postby PaulHaskey » Fri Oct 06, 2017 9:05 pm
Does anyone know how to disassemble the lock on a 60s S type? I need to get the barrel off the door. There is a collar that goes on the front with two holes in the side of it. I'm wondering if a tool locates in these and screws it off.
340jag
Re: Glove box lock
Postby 340jag » Sat Oct 07, 2017 7:58 am
I think your find you need to stick in pin in the small hole , there is a spring loaded catch in there !
PaulHaskey
Re: Glove box lock
Postby PaulHaskey » Thu Nov 02, 2017 11:51 pm
Thanks 340jag
There are two holes in the collar. I've tried a pin in the one hole but I cant feel a spring Obviously you've had yours off Did you use a tool of some description?
PaulHaskey
Re: Glove box lock
Postby PaulHaskey » Sat Nov 04, 2017 4:01 pm
Managed to get it off by putting a pop rivet nail in the hole and gently tapping it with a small hammer, to unscrew the collar.
PaulHaskey
Re: Glove box lock
Postby PaulHaskey » Tue Jan 16, 2018 10:34 pm
Does anyone know where I can get a key cut for one of these? I haven't got an existing one.
piman
Re: Glove box lock
Postby piman » Wed Jan 17, 2018 10:46 am
Hello Paul,
is there a key number anywhere on the lock? There are various stockists of these Wilmot Breeden keys if you can identify it?
Failing that, if you have or can get a spare key, remove the barrel from the lock, insert the key and file down flush with the barrel all protruding latches. Obviously this reduces the (limited) security of the lock but for a glove box I don't think it's a big worry?
peterdpps
Re: Glove box lock
Postby peterdpps » Thu Jan 18, 2018 10:12 am
If it’s any help, my 240 has the same key for the boot and glove box and a different one for ignition and front doors. Might be worth trying the boot key to see if it works.
Having said that I would have thought that,when new, there would have been the same key for all locks.
Pete
Ronniebiggs
Re: Glove box lock
Postby Ronniebiggs » Thu Jan 18, 2018 3:19 pm
As standard, there was one key for doors/ignition and a different one for boot/glove box. The idea was you could let the valet park it without access to the boot etc. Triumphs of the era were the same arrangement.
The keys have the number stamped on them so you just need to order the appropriate key; it used to be possible to get them over the counter but I suspect it's trickier these days. As an aside, the ignition key number is stamped on the face of the ignition barrel. Made the cars a breeze to steal, just look through the back window with a pair of opera glasses, note the number, order a key then steal it at your leisure...why do you think so many were used as getaway cars?
Biggest nuisance is opening the glove box with the engine running - you need to take the key off the ring to do so!
Jay
Jaguar 3.4 Mk2. As original as I can keep it whilst still being safe!
