Removing chrome trim ready for a re-spray
richardhinds
Re: Removing chrome trim ready for a re-spray
Postby richardhinds » Fri Nov 18, 2016 8:20 pm
Hi Alec,
Thanks for responding. Once I got my brain working, I realised the Lucas numbers are in fact shown on the lenses!
I went off to the spray shop, and got the following numbers from my "S" type:
Front indicators ; L690
Front side light. : 461
Tail /brake light. :L687
I purchased a good condition "461", but it appears there is more than one version, and the one I purchased has a much larger diameter hole for the lamp holder. I think this version is used by Rolls Royce.
I'm going to some local Chroming places, to see what they can do with my lights, as the external chrome "bits" are a bit "spotty"
If the bases for the tail lights and front indicators can be re-chromed, I'll be happy, but the front side lights are more or less hidden, and fortunately the only bits which show will clean up.
One day I'll figure out how to attach photos!
Richard
alec2824
Postby alec2824 » Sun Nov 20, 2016 5:15 pm
The base metal used for the door handles, rear lamp plinth, boot number plate plinth are all made from Mazac - a zinc based material, also known as monkey metal. It corrodes and forms blisters with underlying pits. Thus the problem is to get a sooth surface finish without pits - not easy. The side turn indicators door trims were chrome plated brass originally.
richardhinds
Postby richardhinds » Sun Nov 20, 2016 6:51 pm
Hi Alec,
I've spent the afternoon cleaning the front grill and the front side lights (which are quite bad, but fortunately the chromed plate which secures the front lights is perfect), but have you an idea how to remove the glass from the sidelights?
They are quite dirty inside, and I'd love to remove the glass, but it appears the chromed "ring" securing the glass to the body of the light, is permanently fixed.
Richard
alec2824
Postby alec2824 » Wed Nov 23, 2016 8:43 pm
I think they are permanent. Replacements cost about £30 each.
richardhinds
Postby richardhinds » Sat Dec 10, 2016 6:46 pm
Well things are moving on, but slowly! The car is just about back to bare metal, and in better condition than I had hoped, but still needs a few remedial repairs. The front & rear screens were removed by the Paint shop, and I need to locate some new rubber seals.
Has anyone any experience of "M. & C. Wilkinson Ltd", who offer a complete bodywork rubber seal kit for an S type (plus other Jaguars)?
Best wishes to all for the festive season!
Richard
