Window finisher on facelift 1991 coupe
mark.ellington589
Does anyone know the difference between the following parts? Windscreen rubber part number BEC9535. BEC6599. I was searching for 9535 but can’t get one however managed to grab 6599, hopefully it will work if needed.
Re: Window finisher on facelift 1991 coupe
Hi. BEC6559 is for the early facelift convertible and BEC9535 is the early facelift coupe. I’m afraid I don’t know what the physical differences are but I’m supposing there must be some for Jaguar to go to the trouble and expense of listing 2 different part numbers
mark.ellington589
Understood, hopefully it’s the same profile just different sizes. I plan to reuse the one that’s in however if it snaps we might be able to repair it.
mark.ellington589
Interesting. I asked chatGTP the dimensional differences between the coupe and convertible screens, the below response is interesting. From what I can see the convertible is bigger and that part is a lot easier to find, so should be easy for a screen fitter to cut and join to size. I think this could be a good workaround. Thoughts?
ChatGTP response
Sure! The early facelift Jaguar XJS, often referred to as the pre-Ford facelift (circa 1991–1993), was offered in both coupe and convertible body styles. The key differences in size between the two are minimal, but here’s a breakdown:
Jaguar XJS Coupe (Early Facelift, ~1991–1993):
• Length: ~191.7 inches (4872 mm)
• Width: ~70.6 inches (1793 mm)
• Height: ~50 inches (1270 mm)
• Wheelbase: 102 inches (2591 mm)
• Curb Weight: ~3800–3900 lbs (varies by engine)
Jaguar XJS Convertible (Early Facelift, ~1991–1993):
• Height: ~50.6 inches (1285 mm)
• Curb Weight: ~4100–4200 lbs
Key Differences:
• Height: The convertible is slightly taller (~0.6 inches) due to the folded soft top and reinforced chassis.
• Weight: The convertible is heavier by ~200–300 lbs, mostly due to:
ChatGTP response
Key Differences:
The bodyshell is fundamentally the same as regards windscreen framing etc.
The only difference that may justify differing profiles for the windscreen finisher is that the windscreens have a different thickness on Coupes vs Convertibles. I guess this is possibly to do with the fact that the bonded windscreen is a structural element of the car. The glass thickness may mean that the profile of the finisher fits slightly differently. It would be interesting to hear if you notice that the 2 parts seem visually different when you've got them side by side. Or if you feel that that the Convertible version sits differently on your Coupe.
