Member intro
CoXJS
Member intro
Postby CoXJS » Thu Apr 11, 2024 5:42 pm
Hello all,
I have been a member for several years but have never posted on the forum.
I own 1994 4.0 XJS which I am in the process of repairing the windscreen scuttle and some areas around the screen. I have had the car about 9 years and some one had done a job with filler before I bought it. There was water getting in and at the end of last year I decided it needed sorted.
Panels were sourced but I have been putting the job off due to work and cold weather.
Jumped on the forum to find out how to remove the dashboard and airbags.
Not sure if this is the type of forum that like rusty repair photos but I will start a thread once I get welding.
So far the drivers side scuttle has been cut out. I need to repair areas below which is why the dashboard is coming out.
My other Jaguar is a Mk2 which I got in 2020 and other than rebuilding the carbs and getting it running it has been stored since. I am looking forward to starting the project. It had been in a junk yard in California for around 30 years, it is solid but sun damaged. I have no history or information about the car. Jaguar Heritage were able to tell me it had been exported to Venezuela in 1960 as a LHD 3.8 auto. Currently it has a 3.4 manual fitted. I would love to get some details of its history but I think it is always going to be a mystery.
Colin
Renfrewshire
Re: Member intro
Postby ptjs1 » Thu Apr 11, 2024 6:34 pm
Colin,
You may remember my magazine article on this issue back in 2012. And naturally since then, more and more owners have encountered the situation.
As I'm sure you know, the problem will almost definitely have started in the screen flange, rather than directly from the plenum drains, so the screen will need to come out. Be careful when you do that as the mastic retention dams are NLA, so try and carefully save your original.
Hopefully, yours is not so bad, but I've seen the corrosion chase all the way down the A-post and into the sills. So fully check everywhere and cut it all the way back.
You've also probably looked up all the threads in the forum on this issue, but the attached one may be useful.
viewtopic.php?f=45&t=15824
Good luck and start a new thread with some pics for us all to admire!
CoXJS
Re: Member intro
Postby CoXJS » Fri Apr 12, 2024 12:13 am
Thanks Paul,
I hadn't seen the article, I only joined the club when I got the MK2.
There is a fair bit of rust but its not so bad, I have got the dashboard out now.
The screen had been replaced at some point and there was areas which weren't sealed due to the rust. I broke the screen accidentally ( still need to source one).
The bits I am more dreading doing is the front edge of the roof and the gutters. This is my first visit to the forum so I need to have a good trawl through.
Colin
Re: Member intro
Postby davidr » Fri Apr 12, 2024 8:36 pm
Hello Colin and welcome.
We absolutely are the kind of Forum that likes pictures of rusty repairs so please do start a thread when you get into it. We’d love to see it and we could maybe even make a magazine article out of it. Make sure you take plenty of pictures and share them on here please!
drjohnehunt100
Re: Member intro
Postby drjohnehunt100 » Sat Apr 13, 2024 7:30 pm
Also just to note that old copies of the magazine are available online - although you may have to search through them manually to find the article you are interested in.
Re: Member intro
Postby ptjs1 » Sat Apr 13, 2024 9:14 pm
Annoyingly, some of the 2012 issues are missing in the online archives. And my article on the corrosion is in one of those issues!
JimMann
Re: Member intro
Postby JimMann » Sun Apr 14, 2024 10:37 am
Hi there, I have hard copy issues of 2012 and can search for the related article. I can then scan and forward if you PM me an email address, or you can email me at scotland.ambassador@jecregions.org.uk
As you say you are new to the Forum, you may not have spotted another post for a bit of camaraderie. We are hosting Scottish Jaguar Enthusiasts Day at the Riverside Museum in Glasgow on Jun.29.24 - practically on your doorstep Colin. You will find the information from this link to the post.
viewtopic.php?f=11&t=17660
Jim M
Jim Mann
Banchory
