Hi all,
The low brake warning light came on, so dutifully I purchased new brake pads took off the front wheels to discover they are fine. Darn...
So rear ones, great happy to do, but I need to put my car into service mode to release the rear brakes ready for the change. Is there a procedure for this that does not involve a diagnostic machine or garage?
I have a 2009 3.0 ltr XF.
Thank you in advance.
P.S. I can see the post regarding resetting the rear brakes, so already helpful.
James
Rear brake replacement - Service mode
Moderator:cawthrm
- jBlackwell
Re: Rear brake replacement - Service mode
James,
I`ve done these by having the ignition on, holding down the handbrake switch whilst switching the ignition to off. Its worked for me.
- jBlackwell
Hi Mike,
That appears to be the solution. Being Keyless I just have to turn the car off after I have pressed the handbrake button down for a few seconds.
Thanks for the reply.
James
James
