Gearbox oil change
Moderator:cawthrm
eddie_delaine826
Gearbox oil change
Postby eddie_delaine826 » Fri Jul 22, 2022 11:09 pm
My 2010 XF 3.0 litre diesel has 73,000 on the clock and it seems that it ought to have a gearbox oil and filter change as I can find no record of it having had one. Having asked a local independent for a quote for that, as well as an oil service and a fuel pump drive belt replacement, together with what I have read on the forum, I am somewhat confused.
My quote includes for gearbox oil - 10 pints at £19.39/litre a sump pan at £173.27 and 1.5 hrs labour, all plus VAT. Is it necessary to replace the sump pan in order to replace the filter ... or what? The total comes to £589, Is this a reasonable charge for doing a gearbox oil change? Do others have any experience of the work involved and expected cost for this job?
Any help or guidance would be very welcome, thanks.
andypryce
Re: Gearbox oil change
Postby andypryce » Fri Jul 22, 2022 11:25 pm
The oil is expensive and yes I believe the filter and sump pain are one, so you can’t just replace the filter. Certainly that’s the case with the XK and S type, so assume it is with the XF. I have paid not much less than that in the past. Don’t be tempted to go with cheaper oil.
XF Sportbrake 2020 / XK8 1998
