2013 Xf 2.2
Moderator:cawthrm
atkinsonsteve
I decided switch on my rear screen heater and the radio cut out,this happens every time,? As anyone come across this.fingers crossed.thank Steve.
Re: 2013 Xf 2.2
The radio aerial will be embedded in the rear screen so the connection between the two is not as strange as it might appear. There is an antenna amplifier in the system which might not be performing as intended but rather than guessing, it would be better to have the system diagnosed with either Jaguar or Autologic diagnostics to pinpoint the issue. Mike.
