Reversing Camera - Blue Screen
Moderator:cawthrm
Zennan101
Postby Zennan101 » Thu Feb 15, 2018 7:14 pm
Has anyone had experience of the reversing camera failing to a blue screen. Obvious culprit is a break in the boot wiring loom which I can check out but if there’s another possibility any guidance would be appreciated.
Rod
Ex 2010 XF 3.0 Luxury Diesel
Ex 2004 XK8 Coupe
JimboV8
Re: Reversing Camera - Blue Screen
Postby JimboV8 » Thu Feb 15, 2018 9:29 pm
Definitely the first thing to check, many problems documented due to the boot loom.
2012 XKR, Black pack, Aero pack, Speed pack 8) :mrgreen:
​Past:-87'XJS 3.6L, 93'XJ40 3.2L gold, 95'XJ6 4.0L sport, 00'XJ8 3.2L sport, 2005 XK8 4.2L, 2009 X150 5L Portfolio coupe, in that order and enjoyed all of 'em. :D
Zennan101
Postby Zennan101 » Tue Mar 06, 2018 2:07 pm
Problem fixed. Replaced boot loom section of wiring harness. It’s an easy DIY job, the most difficult part is getting the trim fixings to release. Took less than an hour.
I added additional tape on the section that has to flex as this showed signs of abrasion where it passed through the boot lid bodywork. I also took one of the rubber grommets from the scrap loom and added this to protect the new loom where it passed through an unprotected hole.
Ex 2004 XK8 Coupe
Bryangar
Postby Bryangar » Sat Jan 19, 2019 2:28 pm
Going to purchase a boot wiring loom just wondered is it wise to go through Jaguar Main Dealer (are they all different)for certain models OR the ones on Web sites for sale are good enough.Thank you.
Zennan101
Postby Zennan101 » Sat Jan 19, 2019 8:44 pm
I used genuine Jaguar replacement part. Sorry no knowledge of alternatives.
Rod
Ex 2004 XK8 Coupe
stypemike2245
Postby stypemike2245 » Sat Jan 19, 2019 9:02 pm
hi guys just a quick one is it possible to fit a reversing camera to my 2005 sovereign.
mike
DaveNeedham
Postby DaveNeedham » Mon Jan 21, 2019 10:38 am
Mike I would guess you would have to go for an aftermarket one.... check out eBay
There are some Bluetooth devices around now which saves a lot of wiring.
Dave
