XF Electrical puzzle
Posted: Thu Feb 23, 2017 11:02 pm
by dg4cars
2013 XF 2.2 D, Rear Parking sensors , DVD/ Radio , and Bluetooth not working since last week.
Have checked fuses up front ,in the rear, and in the drivers footwell.
No joy !!
Can anyone shed some light please ?
Local Jaguar Dealership unable to come up with a solution ...... :roll:
I am really confused with this :( :( :(
Re: XF Electrical puzzle
Posted: Fri Feb 24, 2017 9:54 am
Do you have a diagnostic code present after interrogation?
You might try a battery disconnect for twenty minutes to clear computers. You will need to re-enter the radio code and reset the clock after doing so. Sometimes this procedure can reset the brains on the car.
Posted: Wed Mar 22, 2017 1:24 am
by dg4cars
Thank you Mike, :D
Apologies for delay in replying :oops:
Car was in local Main Dealership today..........long delay in getting appointment with Master Technician,.....been advised that car will need a new Amplifier @ €1059.00 including labour and VAT, :roll: possibly more if additional work needed. ( "Amplifier is causing short circuit with internal fault") :roll: Lady in Service Department advised me they never came across this fault before??? In addition the car is out of warranty and has a mere 41klms on the clock!! It was a mere €161 today to get the diagnosis. This is a friend's car ,he is less computer literate than me!! :lol:
Best wishes,
Derek
PS . My Stype is still going strong at 195 k miles :D
Posted: Wed Mar 22, 2017 8:24 am
I can only advise getting a code reader tool for personal use. Basic units sell from around £25 on ebay, Derek.
Rather better and more searching is the iCarsoft i930i units from UK Diagnostics for around £90. Several of us here find them very useful and always carry them in the car for on road problem solving!
Also useful is the Torque Pro App suitable for IPhone and Android phones. The App is around £4. The App works with the commonly found Bluetooth ELM327 unit which can be left permanently in the car OBD11 port. This costs around £5 on ebay. Try to find the early 1.5V version rather than the later 2.1V unit. This tool is huge value for money and works well.
Both of the above units can save a small fortune in garage diagnostic costs. As you have seen, Main Dealers coin it in on diagnosis and owners can get the shirt ripped from their backs when taking their cars in for diagnosis. Its all quite unnecessary when small portable diagnosis kit is so easily and cheaply available. Both my units live permanently in my car and have proved there worth on many occasions over the years. I couldn`t afford to run my car unless I had one of these units available. Don`t delay. Go and buy something today! Torque or ICarsoft units are quite easy to use and good results are easy to obtain and codes are quick to be cleared.
As regards the car electronic module, you need to get to it and note the EXACT part number on the case. Give Eurojag or Andy at Auto Reserve a call and see if they have a second hand part available. Second hand parts are often around one third of the price of a new component...sometimes less. Most come with a short warranty and have been tested prior to removal from a scrapped car.
I`ve sometimes taken a seemingly defective ecu module and opened its case. Sometimes you can find bright blue/green copper electrolytic corrosion gunk on the PC board. Sometimes it can be removed and cleaned and the unit starts to work again. On other occasions, just working the module socket and wiring loom plug to break down corrosion resistance hot spots, can get the system going again.
It is important not to panic with this type of fault. Dealers have a habit of being able to frighten the living daylights out of their customers and extract huge sums of cash in the process. Often a fault has nothing to do with the module but just a plug or wiring around it. Diagnosis points towards an issue which may not be a module or sensor issue.
Posted: Wed Mar 22, 2017 10:09 pm
by dg4cars
Mike,
Thank you so much for the advice.
Will get the diagnostic tools straight away.
Tomorrow will follow up with Eurojag and Andy at Autoreserve for price/ availability of secondhand unit.
Cheers Mike,
Many thanks
Derek
