MAF sensor
Moderator:cawthrm
jonthetrike853
MAF sensor
Postby jonthetrike853 » Mon Sep 02, 2024 9:08 am
Xf 3.0 d 2009 . Are both maf meters the same ..ie can I just buy any 2 and replace them ..fault code says maf sensor B . Any help much appreciated tia
Re: MAF sensor
Postby mike020150 » Tue Oct 01, 2024 11:07 am
Currently, Jaguar only lists one MAF sensor part number for the 3 litre diesel XF (cars with VIN R47154 onwards). It's C2P19377. Mike.
cawthrm
Re: MAF sensor
Postby cawthrm » Wed Oct 30, 2024 9:13 am
Did you solve it Jon?
Some of the codes which mention A or B MAF sensor are mismatch codes, i.e. it may not be the airflow sensor that is the issue, just that the engine is not seeing the same airflow as the sensor is reading. I'm painfully aware of this one as it has just occurred on my 2009 3.0D and was caused by cracked inlet manifold / cam cover. 'Restricted Performance' comes up when on turbo boost acceleration due to the air leak. These covers are all one plastic piece (each side of the V) and are a fairly common fault on this engine. The component is relatively cheap in the aftermarket but the labour to install is high, it's a fiddly and long job.
