Engine Management light
Moderator:cawthrm
stevecaswell64425
I have a 2016 (X260 model) XF-S 3.0d and the Engine Management light keeps coming on. I have read the code which is P20EE and cleared it. The car will run for a few days before the Engine Management comes back on. Has anyone encountered the same problem or can through some light on the problem I would be very grateful. Thank you
Re: Engine Management light
Most likely either leaking exhaust or DPF fault according to Dr Google. Simplest and cheapest starting point is get garage to check for exhaust leaks I would say
XF Sportbrake 2020 / XK8 1998
