Headlamp Lens Shattered
nicholls-a5119
Postby nicholls-a5119 » Sat Jun 10, 2023 4:55 pm
I had the horrible shock of finding my driver's side headlamp lens was shattered recently.
I have not hit anything and my dashcam did not record anything when parked up.
I do have a feeling that this may have occurred because I washed off the dust and dirt by spraying with a pressure washer and my thoughts are that the sun was on the car from the front. Had my lights heated up to such a high degree inside the lamp that the sudden exposure to cold water has caused the Perspex to shatter?
Would love to know others thoughts on this?
Also, to warn you not to fall into the same trap as the cost for repair from a Jaguar main dealer is.....Wait for it.....
£3k.
As you probably know the lens can't be changed. It has to be a whole new unit. They are £2,800.
Watch out!
Alan
andypryce
Re: Headlamp Lens Shattered
Postby andypryce » Sat Jun 10, 2023 5:51 pm
Jeez, that’s expensive!
XF Sportbrake 2020 / XK8 1998
nicholls-a5119
Postby nicholls-a5119 » Sun Jun 11, 2023 11:09 am
Yep, the joys of owner a modern Jag.
