Door locks
Posted: Fri May 20, 2022 8:07 pm
by atkinsonsteve
2011 diesel.When I use the fobs to lock the car everything seams to lock,it sounds as though it locked,but pull any Handle and the car opens.thanks Steve.
Re: Door locks
Posted: Sat May 21, 2022 9:29 am
by andypryce
The car will unlock itself if it senses a door is not shut properly, I had same on my 06 XJR, in fact it repeatedly cycled lock/unlock, much to the amusement of passers by. It was a slightly bent metal rod connecting the lock to the handle within the passenger door. Worth taking off the door cards and checking?
Re: Door locks
Posted: Sat May 21, 2022 10:35 am
by JimMann
Hi Steve, are you pulling the handle whilst still holding the key fob? The key fob(s) need to be far enough away from the car to stop the signal from alerting the car to the fact that you are trying to gain entry.
Jim
Re: Door locks
Posted: Sat May 21, 2022 12:34 pm
by atkinsonsteve
Thanks Jim that was the problem,just left the fobs in the faraday bag car locked.Thanks Jim saved me fretting over the weekend.
